[GRASS-user] Emacs grass-mode
José Miguel Barrios jmbarriosg at gmail.com
Tue Apr 24 05:03:30 EDT 2012
Thank you for this valuable contribution.
Cheers,
Miguel
2012/4/23 Tyler Smith <tyler.smith at mail.mcgill.ca>
> Hi again,
> For any Emacs users, I've made some progress tidying up the
> tab-completion for grass-mode. It now supports tab-completion for all
> Grass programs (d.vect, d.rast etc.), as well as all of their
> parameters (i.e., for d.vect, map, color, fcolor etc), and for a few
> cases (map, vect, rast, type) it now completes the actual parameter
> values. This works in both the command line mode igrass, and the
> script editing mode sgrass. These improvements came with switching
> from yas/snippets, which is no longer required, to the built-in
> completion functions.
> The command line interaction is still a little wonky, that's next on
> my list of tasks.
> It's available as a zip file here:
> https://bitbucket.org/tws/grass-mode.el/get/a5da9e04460a.zip
> I'd be interested in hearing from anyone that's tried it.
> Thanks,
> Tyler
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120424/a949bb9e/attachment.html
