[GRASS-user] Copying a location subset to a new location
Luigi Ponti
lponti at inbox.com
Thu Aug 2 13:54:41 PDT 2012
On 02/08/2012 01:26, Markus Neteler wrote:
> On Mon, Jul 30, 2012 at 7:31 PM, Luigi Ponti <lponti at inbox.com> wrote:
>> Hello list.
>> I have been making subset copies of GRASS locations using (the very useful)
>> g.laptop.sh add-on
>> Currently it is the only approach I could find.
> I used r.pack/r.unpack and v.pack/v.unpack in the past which
> packages maps individually. Using g.mlist or likewise you could
> write a "for" loop to package a set of maps.
Thanks Markus:
I did not know about those grass7 addons. The vector versions are there
in the trac svn browser. However, I don't see the raster ones
(r.pack/r.unpack).
At any rate, I have modified g.laptop.sh to run using the g.parser
interface. Cleaned up indentation and comments a bit. I am not sure it
can be useful. Maybe it could function as a g.copy.location
kind-of-thing. It still has a problem with deleting tmp raster folder at
the end of the script. Other than that, it seems to work fine on my Win7
32-bit box under winGRASS 64svn. It is attached for review just in case.
Kind regards,
Luigi
#!/bin/sh
# MODULE: g.laptop_non_interactive.sh
# AUTHOR(S): Otto Dassau <dassau at gbd-consult.de>
# Cleaned-up and edited by Luigi Ponti lponti inbox com
# to run in non interactive mode via the g.parser interface.
# PURPOSE: Script to extract raster and vector data from current
# location into a new one. Data can be copied or extracted
# in current or original resolution and region extent.
# COPYRIGHT: (C) 2002-2012 by the GRASS Development Team
# This program is free software under the GNU General Public
# License (>=v2). Read the file COPYING that comes with GRASS
# for details.
# COMMENTS: Sometimes extracting vector maps at current region extent
# with v.extract doesn't work properly - use copy instead!!
#%module
#% description: Makes a copy of the current location
#%end
#%option
#% guisection: Main
#% key: newLocation
#% type: string
#% description: New (target) location name
#% required : yes
#%end
#%option
#% key: rasterList
#% type: string
#% answer: all
#% description: List of raster maps to copy (separated by space)
#%end
#%option
#% key: vectorList
#% type: string
#% description: List of vector maps to copy (separated by space)
#%end
#%flag
#% key: r
#% answer: 1
#% description: Export raster maps at original instead of current resolution
#%end
#%flag
#% key: v
#% description: Clip vector maps to current region extent
#%end
#%flag
#% key: t
#% description: Put new location in a compressed *.tar.gz archive
#%end
#%flag
#% key: d
#% description: Delete uncompressed location after *.tar.gz archive creation
#%end
if [ -z "$GISBASE" ] ; then
echo "You must be in GRASS GIS to run this program." 1>&2
exit 1
fi
if [ "$1" != "@ARGS_PARSED@" ] ; then
exec g.parser "$0" "$@"
fi
# Get path for current location
eval `g.gisenv`
: ${GISBASE?} ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
LOCATION=$GISDBASE/$LOCATION_NAME/$MAPSET
### cleanup in case of ERROR
cleanup()
if test $LOCNAME
then
echo "delete already build location $LOCNAME?"
\rm -ir $GISDBASE/$LOCNAME/
\rm -rf $CURRWD/tmp/$LOCNAME/
g.remove vect=mxy999
fi
### restore .grassrc6 in case of ERROR
restore()
if test -f $CURRWD/tmp/$LOCNAME/$LOCNAME.grassrc6 ; then
mv $CURRWD/tmp/$LOCNAME/$LOCNAME.grassrc6 $HOME/.grassrc6
fi
### what to do in case of user break:
exitprocedure()
echo ""
echo "User break!"
cleanup
restore
echo "cleanup temporary files and restore .grassrc6"
exit 1
### shell check for user break (signal list: trap -l)
trap "exitprocedure" 2 3 9 15
# Set script parameters
if [ -n "$GIS_OPT_NEWLOCATION" ] ; then
LOCNAME="$GIS_OPT_NEWLOCATION"
fi
if [ -n "$GIS_OPT_RASTERLIST" ] ; then
LISTR="$GIS_OPT_RASTERLIST"
fi
if [ -n "$GIS_OPT_VECTORLIST" ] ; then
LISTV="$GIS_OPT_VECTORLIST"
fi
# Create new location or exit if it exists already
if test -d "$GISDBASE/$LOCNAME" ; then
echo ""
echo "Location $LOCNAME exists already"
echo ""
echo "choose another name"
exit 1
else
mkdir -p $GISDBASE/$LOCNAME/PERMANENT/
fi
### manage linked grassdata files
CGISDBASE=$GISDBASE
CURRWD=$HOME
VECTLOC=$GISDBASE/$LOCNAME/PERMANENT
cd $GISDBASE/$LOCATION_NAME/PERMANENT
cp -f PROJ_INFO PROJ_UNITS DEFAULT_WIND $VECTLOC
cd $LOCATION
cp -f WIND $VECTLOC
#cp WIND $VECTLOC/DEFAULT_WIND
cd $CURRWD
### Copy rasters
mkdir -p $CURRWD/tmp/$LOCNAME/rast/
mkdir $VECTLOC/colr
### save current region and resolution for later restore
CEWRES=`g.region -p | awk '/ewres:/ {printf "%i\n",$2}'`
CNSRES=`g.region -p | awk '/nsres:/ {printf "%i\n",$2}'`
#CEWRES=`g.region -p | awk '/ewres:/ {printf "%.2f\n",$2}'`
#CNSRES=`g.region -p | awk '/nsres:/ {printf "%.2f\n",$2}'`
if [ "$LISTR" = "all" ] ; then
for i in `ls $VECTLOC/cell/`
do
echo "COPY $i DATA TO $LOCNAME"
### Find mapset data and copy to new location
g.findfile el=colr file=$i > $CURRWD/tmp/$LOCNAME/rast/$i.col
RASTCOL=`cat $CURRWD/tmp/$LOCNAME/rast/$i.col | grep "file" | cut -b 7- | sed -e "s/'//g"`
if [ "$RASTCOL" = "" ] ; then
echo "map $i has no colortable file"
else
if [ -d $VECTLOC/colr ] ; then
cp $RASTCOL $VECTLOC/colr/
echo "copy colr/$i"
fi
fi
g.findfile el=cell file=$i > $CURRWD/tmp/$LOCNAME/rast/$i.cell
RASTCELL=`cat $CURRWD/tmp/$LOCNAME/rast/$i.cell | grep "file" | cut -b 7- | sed -e "s/'//g"`
if [ "$RASTCELL" = "" ] ; then
echo "cell/$i doesn't exist"
else
if [ -d $VECTLOC/cell ] ; then
cp $RASTCELL $VECTLOC/cell/
echo "copy cell/$i"
else
mkdir $VECTLOC/cell
echo "copy cell/$i"
fi
fi
g.findfile el=cellhd file=$i > $CURRWD/tmp/$LOCNAME/rast/$i.cellhd
RASTCHD=`cat $CURRWD/tmp/$LOCNAME/rast/$i.cellhd | grep "file" | cut -b 7- | sed -e "s/'//g"`
if [ "$RASTCHD" = "" ] ; then
echo "cellhd/$i doesn't exist"
else
if [ -d $VECTLOC/cellhd ] ; then
cp $RASTCHD $VECTLOC/cellhd/
echo "copy cellhd/$i"
else
mkdir $VECTLOC/cellhd
fi
fi
g.findfile el=cell_misc file=$i > $CURRWD/tmp/$LOCNAME/rast/$i.cell_misc
RASTCMISC=`cat $CURRWD/tmp/$LOCNAME/rast/$i.cell_misc | grep "file" | cut -b 7- | sed -e "s/'//g"`
if [ "$RASTCMISC" = "" ] ; then
echo "/cell_misc/$i doesn't exist"
else
if [ -d "$VECTLOC/cell_misc/$i" ] ; then
cp -r $RASTCMISC/* $VECTLOC/cell_misc/$i
echo "copy cell_misc/$i"
else
mkdir -p $VECTLOC/cell_misc/$i
fi
fi
g.findfile el=fcell file=$i > $CURRWD/tmp/$LOCNAME/rast/$i.fcell
RASTFCELL=`cat $CURRWD/tmp/$LOCNAME/rast/$i.fcell | grep "file" | cut -b 7- | sed -e "s/'//g"`
if [ "$RASTFCELL" = "" ] ; then
echo "fcell/$i doesn't exist"
else
if [ -d $VECTLOC/fcell ] ; then
cp $RASTFCELL $VECTLOC/fcell/
echo "copy fcell/$i"
else
mkdir $VECTLOC/fcell
fi
fi
g.findfile el=dcell file=$i > $CURRWD/tmp/$LOCNAME/rast/$i.dcell
RASTDCELL=`cat $CURRWD/tmp/$LOCNAME/rast/$i.dcell | grep "file" | cut -b 7- | sed -e "s/'//g"`
if [ "$RASTDCELL" = "" ] ; then
echo "dcell/$i doesn't exist"
else
if [ -d $VECTLOC/dcell ] ; then
cp $RASTDCELL $VECTLOC/dcell
echo "copy dcell/$i"
else
mkdir $VECTLOC/dcell
cp $RASTDCELL $VECTLOC/dcell/
fi
fi
g.findfile el=g3dcell file=$i > $CURRWD/tmp/$LOCNAME/rast/$i.g3dcell
RASTGD=`cat $CURRWD/tmp/$LOCNAME/rast/$i.g3dcell | grep "file" | cut -b 7- | sed -e "s/'//g"`
if [ "$RASTGD" = "" ] ; then
echo "g3dcell/$i doesn't exist"
echo ""
else
if [ -d $VECTLOC/g3dcell ] ; then
cp $RASTGD $VECTLOC/g3dcell/
echo "copy g3dcell/$i"
echo ""
else
mkdir $VECTLOC/g3dcell
echo ""
fi
fi
done
else
for i in $LISTR
do
RASTCOL=`cat $CURRWD/tmp/$LOCNAME/rast/$i.col | grep "file" | cut -b 7- | sed -e "s/$i'//g"`
if [ -f $RASTCOL$i ] ; then
cp $RASTCOL$i $CURRWD/tmp/$LOCNAME/rast/$i.colr
else
fi
if [ "$GIS_FLAG_R" -eq 1 ] ; then
### Find original data resolution for export
g.findfile el=cellhd file=$i > $CURRWD/tmp/$LOCNAME/rast/$i.hd
RASTHD=`cat $CURRWD/tmp/$LOCNAME/rast/$i.hd | grep "file" | cut -b 7- | sed -e "s/'//g"`
OEWRES=`cat $RASTHD | awk '/e-w resol:/ {printf "%i\n",$3}'`
ONSRES=`cat $RASTHD | awk '/n-s resol:/ {printf "%i\n",$3}'`
# OEWRES=`cat $RASTHD | awk '/e-w resol:/ {printf "%.2f\n",$3}'`
# ONSRES=`cat $RASTHD | awk '/n-s resol:/ {printf "%.2f\n",$3}'`
g.region ewres=$OEWRES nsres=$ONSRES -a
### Export map
echo "export raster map $i for later import"
r.out.ascii in=$i out=$CURRWD/tmp/$LOCNAME/rast/$i.asc
echo ""
else
### Export map
echo ""
fi
done
fi
### Copy vectors
mkdir -p $CURRWD/tmp/$LOCNAME/vector
# Get current region extent as area map
if [ "$GIS_FLAG_V" -eq 1 ] ; then
v.in.region output=mxy999 type=area
fi
### extract vector data into new location
if [ "$LISTV" = "all" ] ; then
$LISTV = `ls $VECTLOC/vector/`
fi
for i in $LISTV
do
echo "extract vector map $i from current region extent"
g.findfile el=vector file=$i > $CURRWD/tmp/$LOCNAME/vector/$i
VECTMAP=`cat $CURRWD/tmp/$LOCNAME/vector/$i | grep "file" | cut -b 7- | sed -e "s/$i'//g"`
if [ -d $VECTLOC/vector/ ] ; then
v.select ainput=$i binput=mxy999 output=mxyarea999
cp -r $VECTMAP../vector/mxyarea999 $VECTLOC/vector/$i
else
mkdir -p $VECTLOC/vector/
fi
if [ -f $VECTMAP../dbf/$i ] ; then
if [ -d $VECTLOC/dbf/ ] ; then
cp $VECTMAP../dbf/mxyarea999.dbf $VECTLOC/dbf/$i.dbf
else
mkdir -p $VECTLOC/dbf
fi
fi
g.remove -f vect=mxyarea999
g.remove -f vect=mxy999
else
### copy vector data into new location
echo "copy vector map $i"
cp -r $VECTMAP../vector/$i $VECTLOC/vector/
else
fi
if [ -f $VECTMAP../dbf/$i.dbf ] ; then
cp $VECTMAP../dbf/$i.dbf $VECTLOC/dbf/
else
mkdir -p $VECTLOC/dbf/
fi
fi
fi
done
### In case no files were chosen for export at all
if [ "$LISTR" = "" -a "$LISTV" = "" ] ; then
echo "No files chosen - sorry!"
echo "...removing already created location $LOCNAME"
cleanup
exit 1
fi
### If no raster import is needed
if [ "$LISTR" = "" -o "$LISTR" = "all" ] ; then
if [ "$GIS_FLAG_T" -eq 1 ] ; then
cd $GISDBASE
tar czvf ~/$LOCNAME.tar.gz $LOCNAME/*
if [ "$GIS_FLAG_D" -eq 1 ] ; then
else
echo ""
echo "Location $LOCNAME kept in $GISDBASE"
fi
else
echo ""
echo "Location $LOCNAME created in $GISDBASE"
echo ""
echo "bye..."
fi
else
### Else raster import into new location is needed
### save .grassrc6
if test -e $HOME/.grassrc6 ; then
mv $HOME/.grassrc6 $CURRWD/tmp/$LOCNAME/$LOCNAME.grassrc6
fi
### change to new location for import of raster data
LOCATION_NAME=$LOCNAME
GISDBASE=$CGISDBASE
MAPSET=PERMANENT
echo "LOCATION_NAME: $LOCNAME" > $HOME/.grassrc6
echo "MAPSET: PERMANENT" >> $HOME/.grassrc6
echo "DIGITIZER: none" >> $HOME/.grassrc6
echo "GISDBASE: $GISDBASE" >> $HOME/.grassrc6
export LOCATION_NAME=$LOCNAME
export GISBASE=$GISBASE
export GISRC=$HOME/.grassrc6
export PATH=$PATH:$GISBASE/bin:$GISBASE/scripts
### import raster files
echo ""
echo "import raster maps to location $LOCNAME"
echo ""
echo "!! changed into new location $LOCNAME for import !!"
cd $CURRWD/tmp/$LOCNAME/rast
LISTRA=`ls *.asc`
for i in $LISTRA
do
NEWNAME=`basename $i .asc`
r.in.ascii in=$i out=$NEWNAME
# r.support -r $NEWNAME
done
LISTC=`ls *.colr`
mkdir -p $GISDBASE/$LOCNAME/PERMANENT/colr
for i in $LISTC
do
NEWNAME2=`basename $i .colr`
cp $CURRWD/tmp/$LOCNAME/rast/$i $GISDBASE/$LOCNAME/PERMANENT/colr/$NEWNAME2
done
### restore .grassrc6 and cleanup
restore
echo ""
echo "!! changed back into current location !!"
#cleanup
g.region nsres=$CNSRES ewres=$CEWRES -a
### Tar the new location if requested
cd $GISDBASE
echo ""
echo "$LOCNAME.tar.gz written to $HOME"
echo ""
rm -rf $GISDBASE/$LOCNAME/
else
echo ""
fi
else
echo ""
echo ""
echo "bye..."
fi
fi
#restore .grassrc6 and cleanup
restore
rm -rf $CURRWD/tmp
