[GRASS-user] Raster with bounding box
Sylvain Maillard sylvain.maillard at gmail.com
Mon Aug 13 02:40:37 PDT 2012
I would say you have at least 3 way to do that:
- use your bounding box points to make a vrt raster for each of your png
files
- use gdalwarp to georectify your png files
- "manually" write the POINTS files to use with i.rectify (try first to
georectify 1 file by hand with the "georectify tool", and then go to the
group/subgroup directories to study the files structure)
for each of those solutions you will need to write a small script to
automate the process for all of your files ;)
cheers,
Sylvain
2012/8/13 Richard Chirgwin <rchirgwin at ozemail.com.au>
> Hi all,
> I have a bunch of png format images to import. I also have a csv of the
> images' bounding boxes.
> Rather than working by hand, which would be slow - is there any quick way
> to turn the bounding boxes into a POINTS file for each image, to automate
> the georectification?
> Cheers,
> Richard
> ______________________________**_________________
> grass-user mailing list
> http://lists.osgeo.org/**mailman/listinfo/grass-user<http://lists.osgeo.org/mailman/listinfo/grass-user>
-------------- section suivante --------------
Une pi?ce jointe HTML a ?t? nettoy?e...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120813/e2514d2a/attachment.html>
