[GRASS-user] update cat column in vector data set
Moritz Lennert mlennert at club.worldonline.be
Fri Aug 17 02:38:53 PDT 2012
On 16/08/12 20:23, Stefan Luedtke wrote:
> That helped for my general understanding, thanks a lot, but I can not
> figure out how.
> Can anyone just give a few hints on the procedure, basically, how to
> continue after "v.clean", please?
You could try using v.extract with something list list=1-9999 in order
to create a new vector file which contains only those polygons (and
their attributes in the table) which exist in your cleaned file.
Moritz
> Cheers,
> Stefan
> On Thu, 2012-08-16 at 16:29 +0200, Markus Metz wrote:
>> On Thu, Aug 16, 2012 at 1:10 PM, Stefan Luedtke<sluedtke at gfz-potsdam.de  <mailto:sluedtke at gfz-potsdam.de>>  wrote:
>> >  Dear friends,
>> >  I am struggling with the following point.
>> >  I have created a shape of subbasins based on a raster data set. Since this
>> >  yields some tiny (pixel size) areas, I run"v.clean"  with a certain
>> >  threshold to remove/append those artifacts. However, the resulting vector
>> >  data set still holds all categories of the old one, even so, some areas have
>> >  been removed.
>> This is because several areas can belong to the same category, e.g.
>> basin id, and the category of a deleted area may still be used by
>> another, existing area. BTW, it is not uncommon that one raster basin
>> is represented by several vector areas.
>> >  So my question: How can I update these values that the number of categories
>> >  matches the number of areas?
>> You can delete the table and create a new table. Otherwise, entries in
>> the attribute table that are no longer used do not do harm.
>> HTH,
>> Markus M
>> >  I tried v.category (but der is not update function).
>> >  Cheers,
>> >  Stefan
>> >  _______________________________________________
>> >  grass-user mailing list
>> >  grass-user at lists.osgeo.org  <mailto:grass-user at lists.osgeo.org>
>> >  http://lists.osgeo.org/mailman/listinfo/grass-user
