[GRASS-user] Importing From GeoPDF
Dave Kindem dkindem at gmail.com
Sun Aug 19 08:00:21 PDT 2012
Hello,
I'm trying to import a new-style GeoPDF USGS topo map into an existing GRASS location as a raster layer.  I've converted the file to a GeoTIFF with gdal_translate and then adjusted to projection using gdalwarp.  When I import the GeoTIFF into GRASS, each color band is written as a separate layer:
> r.in.gdal input=/Users/dkindem/MI_Grand_Haven_20110923_TM_geo_wgs.tif output=MI_Grand_Haven_20110923_TM_geo_wgs
> Projection of input dataset and current location appear to match
> r.in.gdal complete. Raster map <MI_Grand_Haven_20110923_TM_geo_wgs.red> created.
> r.in.gdal complete. Raster map <MI_Grand_Haven_20110923_TM_geo_wgs.green> created.
> r.in.gdal complete. Raster map <MI_Grand_Haven_20110923_TM_geo_wgs.blue> created.
> (Sun Aug 19 10:50:07 2012) Command finished (2 sec)
Each layer displays (in monochrome), but I'd like to create a single, color, layer.
I'm curious to know if others have encountered this, or have thoughts on the issue.
Thanks in advance,
Dave
Dave Kindem
Grand Haven, MI
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120819/80c8c272/attachment.html>
