[GRASS-user] Importing From GeoPDF
Michael Barton Michael.Barton at asu.edu
Sun Aug 19 13:53:13 PDT 2012
If you have 3 red, green, blue channels, you can combine them to display using d.rgb (under the special raster menu button in the layer manager) or combine them into a single color map using r.composite.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice:  480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax:          480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Aug 19, 2012, at 12:00 PM, <grass-user-request at lists.osgeo.org<mailto:grass-user-request at lists.osgeo.org>>
 wrote:
From: Dave Kindem <dkindem at gmail.com<mailto:dkindem at gmail.com>>
Subject: [GRASS-user] Importing From GeoPDF
Date: August 19, 2012 8:00:21 AM MST
To: <grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>>
Hello,
I'm trying to import a new-style GeoPDF USGS topo map into an existing GRASS location as a raster layer.  I've converted the file to a GeoTIFF with gdal_translate and then adjusted to projection using gdalwarp.  When I import the GeoTIFF into GRASS, each color band is written as a separate layer:
r.in.gdal input=/Users/dkindem/MI_Grand_Haven_20110923_TM_geo_wgs.tif output=MI_Grand_Haven_20110923_TM_geo_wgs
Projection of input dataset and current location appear to match
r.in.gdal complete. Raster map <MI_Grand_Haven_20110923_TM_geo_wgs.red> created.
r.in.gdal complete. Raster map <MI_Grand_Haven_20110923_TM_geo_wgs.green> created.
r.in.gdal complete. Raster map <MI_Grand_Haven_20110923_TM_geo_wgs.blue> created.
(Sun Aug 19 10:50:07 2012) Command finished (2 sec)
Each layer displays (in monochrome), but I'd like to create a single, color, layer.
I'm curious to know if others have encountered this, or have thoughts on the issue.
Thanks in advance,
Dave
Dave Kindem
Grand Haven, MI
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120819/043be8f3/attachment.html>
