[GRASS-user] Precision of raster/vector float values
Thu Aug 23 14:43:00 PDT 2012
Markus Metz wrote:
> > I have a GRASS raster map which contains small values (e.g 2.5e-15) among
> > others.
> This is (dangerously) close to the IEEE limit of double precision
> floating point values. If GRASS tests for fp precision, it regards
> (absolute) values smaller than 1.0e-15 (GRASS_EPSILON) as zero.
2.5e-15 is close to the "epsilon" value for IEEE double precision.
This just means that (1.0 + 2.5e-15) is only barely distinguishable
from 1.0. It has no relevance to the representation of small numbers.
A double can represent numbers as low as ~2.225e-308 with no loss of
precision.
If GRASS_EPSILON is being used to compare absolute (rather then
relative) difference, that's a bug.
