[GRASS-user] interpolation from massive vector point input
Micha Silver
micha at arava.co.il
Mon Aug 27 22:53:17 PDT 2012
On 27/08/2012 12:58, Johannes Radinger wrote:
> Hi,
> I get a text file from a hydromorphological model which includes
> an massive amount of geographical points with attributes (velocity,depth,..),
> which I input using v.in.ascii (around 120000 points).
> The points are located in a river (20 m widht) in a resolution of
> appr. 20x20 cm,
> but this is not fixed and depending on their location within in the river
> (points in the outer bends show rougher resolution then points in the
> inner bends).
> So these points are not regularly (in the sense of raster map) distributed.
> Anyway I want to generate a raster surface (resolution = appr. 0.25)
> from the vector points attributes, e.g a surface of velocity and one
> for depth.
> Additionally to the vector points there is a line vector indicating
> the shore line
> of the river (depth=0 and velocity = 0).
I would use the shoreline to create a polygon of the river area. THen
convert that polygon to a raster, and use it as a MASK. Once the MASK is
in place, the interpolation will work only on the area of the river.
And as Madi suggested, try v.surf.rst.
> Now I am looking for a method for interpolation of these points. I
> found v.surf.icw
> which would take into account that there is a shoreline which is not overflown
> by the water (interpolates within the river). But it is not recommended for such
> massive data point input. Is there any other recommendable way fur such
> a purpose (considering the shore line and that there is 0 velocity and
> 0 depth on land?
> Any suggestions are welcome!
> Thank you,
> /johannes
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
> This mail was received via Mail-SeCure System.
Micha Silver
052-3665918
