[GRASS-user] FW: r.lake issues
Maris Nartiss
maris.gis at gmail.com
Tue Aug 28 08:04:13 PDT 2012
Hello,
please check following things:
1) water level at seed point/area is above terrain (provided DEM);
2) seed point/area is located within current computational region
(just run g.region rast=my_dem before r.lake);
3) seed point/area has values > 0 (quirk of current implementation).
Good luck!
Maris.
PS. 3rd check probably could be eliminated by slight alteration of
r.lake code. Just a note to myself ;)
2012/8/28 ambrish dhaka <ambijat at hotmail.com>:
> ________________________________
> From: ambijat at hotmail.com
> To: qgis-user at lists.osgeo.org
> Subject: r.lake issues
> Date: Tue, 28 Aug 2012 04:55:59 +0000
> HI! ALL
> I have been trying to generate a lake feature from dem and seed raster files
> using r.lake, this is information below.
> The areas are not created as values can be seen below.
> r.lake dem=e15234 at user1 seed=seed at user1 wl=50 lake=seed50
> Lake depth from 0.000000 to 0.000000
> Lake area 0.000000 square meters
> Lake volume 0.000000 cubic meters
> Volume is correct only if lake depth (terrain raster map) is in meters
> Successfully finished
> What could be the reason.
> AMBRISH DHAKA
> THANKS! IN ADVANCE
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
