[GRASS-user] OSError importing CSV file with a Python Script
Andrés Silva
andres.silva.m at gmail.com
Thu Aug 30 09:31:48 PDT 2012
Hi everyone!
I am trying to wrote a Python Script for importing CSV files to GRASS
GIS without start GRASS. But I am getting a OSError:
>>> import grass.script as g
>>> g.run_command("db.in.ogr", dsn="table.csv", output="test")
File "<stdin>", line 1, in <module>
File "/usr/lib/grass64/etc/python/grass/script/core.py", line
189, in run_command
ps = start_command(*args, **kwargs)
177, in start_command
return Popen(args, **popts)
File "/usr/lib/grass64/etc/python/grass/script/core.py", line 56,
in __init__
startupinfo, creationflags)
File "/usr/lib/python2.7/subprocess.py", line 679, in __init__
errread, errwrite)
File "/usr/lib/python2.7/subprocess.py", line 1249, in _execute_child
raise child_exception
OSError: [Errno 2] No such file or directory
I attached a IPython Notebook example (print version
https://dl.dropbox.com/u/473460/import_table_test.html). The command
works fine in GRASS console, GRASS Python console and the script
executed inside GRASS.
Any help?
*Andrés Silva*
------------ pr?xima parte ------------
Se ha borrado un adjunto en formato HTML...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20120830/67601310/attachment.html>
"metadata": {
"name": "import_table"
"nbformat": 2,
"worksheets": [
"cells": [
"cell_type": "code",
"collapsed": true,
"input": [
"import grass.script as g"
"language": "python",
"outputs": [],
"prompt_number": 1
"collapsed": false,
"input": [
"# test table exist",
"!ls *.csv*"
"outputs": [
"output_type": "stream",
"stream": "stdout",
"text": [
"table.csv table.csvt"
"prompt_number": 2
"collapsed": false,
"input": [
"!cat table.csv"
"outputs": [
"stream": "stdout",
"text": [
"edad,peso,nombre",
"1,2,felipe",
"3,4,andres"
"prompt_number": 3
"collapsed": false,
"input": [
"!cat table.csvt"
"outputs": [
"stream": "stdout",
"text": [
"Integer,Integer,Text"
"prompt_number": 4
"collapsed": false,
"input": [
"g.run_command(\"db.in.ogr\", dsn=\"table.csv\", output=\"test\")"
"outputs": [
"ename": "OSError",
"evalue": "[Errno 2] No such file or directory",
"output_type": "pyerr",
"traceback": [
"\u001b[0;31m---------------------------------------------------------------------------\u001b[0m\n\u001b[0;31mOSError\u001b[0m Traceback (most recent call last)",
"\u001b[0;32m/home/andres/<ipython-input-5-f9b40c640d3d>\u001b[0m in \u001b[0;36m<module>\u001b[0;34m()\u001b[0m\n\u001b[0;32m----> 1\u001b[0;31m \u001b[0mg\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mrun_command\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0;34m\"db.in.ogr\"\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mdsn\u001b[0m\u001b[0;34m=\u001b[0m\u001b[0;34m\"table.csv\"\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0moutput\u001b[0m\u001b[0;34m=\u001b[0m\u001b[0;34m\"test\"\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m",
"\u001b[0;32m/usr/lib/grass64/etc/python/grass/script/core.pyc\u001b[0m in \u001b[0;36mrun_command\u001b[0;34m(*args, **kwargs)\u001b[0m\n\u001b[1;32m 187\u001b[0m \u001b[0;34m@\u001b[0m\u001b[0;32mreturn\u001b[0m \u001b[0mexit\u001b[0m \u001b[0mcode\u001b[0m \u001b[0;34m(\u001b[0m\u001b[0;36m0\u001b[0m \u001b[0;32mfor\u001b[0m \u001b[0msuccess\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 188\u001b[0m \"\"\"\n\u001b[0;32m--> 189\u001b[0;31m \u001b[0mps\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0mstart_command\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0;34m*\u001b[0m\u001b[0margs\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0;34m**\u001b[0m\u001b[0mkwargs\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 190\u001b[0m \u001b[0;32mreturn\u001b[0m \u001b[0mps\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mwait\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 191\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n",
"\u001b[0;32m/usr/lib/grass64/etc/python/grass/script/core.pyc\u001b[0m in \u001b[0;36mstart_command\u001b[0;34m(prog, flags, overwrite, quiet, verbose, **kwargs)\u001b[0m\n\u001b[1;32m 175\u001b[0m \u001b[0msys\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mstderr\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mflush\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 176\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m--> 177\u001b[0;31m \u001b[0;32mreturn\u001b[0m \u001b[0mPopen\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0margs\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0;34m**\u001b[0m\u001b[0mpopts\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 178\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 179\u001b[0m \u001b[0;32mdef\u001b[0m \u001b[0mrun_command\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0;34m*\u001b[0m\u001b[0margs\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0;34m**\u001b[0m\u001b[0mkwargs\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n",
"\u001b[0;32m/usr/lib/grass64/etc/python/grass/script/core.pyc\u001b[0m in \u001b[0;36m__init__\u001b[0;34m(self, args, bufsize, executable, stdin, stdout, stderr, preexec_fn, close_fds, shell, cwd, env, universal_newlines, startupinfo, creationflags)\u001b[0m\n\u001b[1;32m 54\u001b[0m \u001b[0mpreexec_fn\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mclose_fds\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mshell\u001b[0m\u001b[0;34m,\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 55\u001b[0m \u001b[0mcwd\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0menv\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0muniversal_newlines\u001b[0m\u001b[0;34m,\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m---> 56\u001b[0;31m startupinfo, creationflags)\n\u001b[0m\u001b[1;32m 57\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 58\u001b[0m \u001b[0mPIPE\u001b[0m \u001b[0;34m=\u001b[0m \u001b[0msubprocess\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mPIPE\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n",
"\u001b[0;32m/usr/lib/python2.7/subprocess.pyc\u001b[0m in \u001b[0;36m__init__\u001b[0;34m(self, args, bufsize, executable, stdin, stdout, stderr, preexec_fn, close_fds, shell, cwd, env, universal_newlines, startupinfo, creationflags)\u001b[0m\n\u001b[1;32m 677\u001b[0m \u001b[0mp2cread\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mp2cwrite\u001b[0m\u001b[0;34m,\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 678\u001b[0m \u001b[0mc2pread\u001b[0m\u001b[0;34m,\u001b[0m \u001b[0mc2pwrite\u001b[0m\u001b[0;34m,\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m--> 679\u001b[0;31m errread, errwrite)\n\u001b[0m\u001b[1;32m 680\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 681\u001b[0m \u001b[0;32mif\u001b[0m \u001b[0mmswindows\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n",
"\u001b[0;32m/usr/lib/python2.7/subprocess.pyc\u001b[0m in \u001b[0;36m_execute_child\u001b[0;34m(self, args, executable, preexec_fn, close_fds, cwd, env, universal_newlines, startupinfo, creationflags, shell, p2cread, p2cwrite, c2pread, c2pwrite, errread, errwrite)\u001b[0m\n\u001b[1;32m 1247\u001b[0m \u001b[0;32mif\u001b[0m \u001b[0mfd\u001b[0m \u001b[0;32mis\u001b[0m \u001b[0;32mnot\u001b[0m \u001b[0mNone\u001b[0m\u001b[0;34m:\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 1248\u001b[0m \u001b[0mos\u001b[0m\u001b[0;34m.\u001b[0m\u001b[0mclose\u001b[0m\u001b[0;34m(\u001b[0m\u001b[0mfd\u001b[0m\u001b[0;34m)\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0;32m-> 1249\u001b[0;31m \u001b[0;32mraise\u001b[0m \u001b[0mchild_exception\u001b[0m\u001b[0;34m\u001b[0m\u001b[0m\n\u001b[0m\u001b[1;32m 1250\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n\u001b[1;32m 1251\u001b[0m \u001b[0;34m\u001b[0m\u001b[0m\n",
"\u001b[0;31mOSError\u001b[0m: [Errno 2] No such file or directory"
"prompt_number": 5
"collapsed": false,
"input": [
"# others commands works",
"g.parse_command(\"g.region\", flags=\"p\")"
"outputs": [
"output_type": "pyout",
"prompt_number": 7,
"text": [
"{'cells: 1': None,",
" 'cols: 1': None,",
" 'datum: wgs84': None,",
" 'east: 1E': None,",
" 'ellipsoid: wgs84': None,",
" 'ewres: 1': None,",
" 'north: 1N': None,",
" 'nsres: 1': None,",
" 'projection: 3 (Latitud - Longitud.)': None,",
" 'rows: 1': None,",
" 'south: 0': None,",
" 'west: 0': None,",
" 'zone: 0': None}"
"prompt_number": 7
