[GRASS-user] Does v.kernel have to take 16+ hours?
Aren Cambre
aren at arencambre.com
Thu Dec 6 06:13:17 PST 2012
Thanks. I am using EPSG:3081 <http://spatialreference.org/ref/epsg/3081/>,
and its unit is meters. So is it the case that a SD of *x* on EPSG:3081
means a search radius of 4*x *meters? If so, why 4*x*?
Aren
On Thu, Dec 6, 2012 at 2:29 AM, Markus Metz
<markus.metz.giswork at gmail.com>wrote:
> On Thu, Dec 6, 2012 at 3:58 AM, Aren Cambre <aren at arencambre.com> wrote:
> > It's gotten slow again. This run will probably take more than 10 hours.
> > However, I am using a standard deviation of 1000. Is that what could be
> > causing this?
> Yes. With a standard deviation of 1000, the search radius is now 4000,
> that is, for each cell a 8000x8000 box is searched. With many densely
> packed points, this can take quite some time.
> Markus M
> > v.kernel input=tickets at PERMANENT output=tickets_new_heatmap_1000
> > stddeviation=1000
> > STDDEV: 1000.000000
> > RES: 18.290457 ROWS: 2370 COLS: 2650
> > Writing output raster map using smooth parameter=1000.000000.
> > Normalising factor=6482635.018778.
> > On Sat, Nov 24, 2012 at 9:03 PM, Aren Cambre <aren at arencambre.com>
> wrote:
> >> I installed r53983. The v.kernel execution that took almost a day now
> >> executes in 25.5 minutes. Thank you!
> >> Aren
> >> On Fri, Nov 23, 2012 at 12:51 PM, Markus Metz
> >> <markus.metz.giswork at gmail.com> wrote:
> >>> On Fri, Nov 23, 2012 at 5:35 PM, Aren Cambre <aren at arencambre.com>
> wrote:
> >>> > Thanks!
> >>> > I am not familiar with GRASS's release customs. Will this become part
> >>> > of a
> >>> > binary release soon, or should I just pull down the latest release in
> >>> > the
> >>> > 6.4.2 trunk? I'm assuming this has been merged into the trunk...
> >>> It should be available as a binary for Windows by tomorrow in the
> >>> nightly builds [0].
> >>> Markus M
> >>> [0] http://wingrass.fsv.cvut.cz/grass64/
> >>> > Aren
> >>> > On Fri, Nov 23, 2012 at 7:32 AM, Markus Metz
> >>> > wrote:
> >>> >> On Fri, Nov 23, 2012 at 2:07 PM, Aren Cambre <aren at arencambre.com>
> >>> >> wrote:
> >>> >> > Isn't taking about 10,000% too much time considered a bug? :-)
> >>> >> Hmm, yes. v.kernel is fixed in devbr6 and relbr6 with r53982 and
> >>> >> r53983, respectively.
> >>> >> Markus M
> >>> >> > On Nov 23, 2012 5:11 AM, "Markus Metz"
> >>> >> > wrote:
> >>> >> >> On Fri, Nov 23, 2012 at 4:14 AM, Aren Cambre <
> >>> >> >> wrote:
> >>> >> >> > I'm able to reproduce reliably here. I'll email you details
> >>> >> >> > privately.
> >>> >> >> Thanks. I can confirm that v.kernel takes a long time in GRASS 6
> >>> >> >> with
> >>> >> >> the settings provided by you. It does not crash, however.
> >>> >> >> I can speed up v.kernel in GRASS 6 to complete in 10 minutes
> >>> >> >> instead
> >>> >> >> of 16+ hours, but I am not sure if this fix can/will go into
> GRASS
> >>> >> >> 6.4
> >>> >> >> because by now only bugs should be fixed.
> >>> >> >> Markus M
> >>> >> >> > Aren
> >>> >> >> > On Thu, Nov 22, 2012 at 9:02 AM, Markus Metz
> >>> >> >> > wrote:
> >>> >> >> >> On Sat, Nov 17, 2012 at 4:06 PM, Aren Cambre
> >>> >> >> >> wrote:
> >>> >> >> >> > I have a dataset of just over 700,000 incidents that
> happened
> >>> >> >> >> > in
> >>> >> >> >> > square-ish
> >>> >> >> >> > Texas county that's about 30 miles on each side.
> >>> >> >> >> > Here's the parameters reported by v.kernel as it's
> executing:
> >>> >> >> >> > STDDEV: 1000.000000
> >>> >> >> >> > RES: 111.419043 ROWS: 458 COLS: 447
> >>> >> >> >> > I am running this on a Windows 7 x64 machine with 8 GB RAM
> and
> >>> >> >> >> > an
> >>> >> >> >> > Intel
> >>> >> >> >> > Core
> >>> >> >> >> > i7 Q720 1.6 GHz with 4 physical cores. I notice that it's
> not
> >>> >> >> >> > multithreaded,
> >>> >> >> >> > only using 1 core.
> >>> >> >> >> > It takes about 16 hours to complete. Is this correct? I'd
> like
> >>> >> >> >> > to
> >>> >> >> >> > use
> >>> >> >> >> > this
> >>> >> >> >> > on a dataset with closer to 5 million records, and I'm
> really
> >>> >> >> >> > concerned
> >>> >> >> >> > how
> >>> >> >> >> > long it may take.
> >>> >> >> >> The time required by v.kernel is a function of the number of
> >>> >> >> >> cells
> >>> >> >> >> and
> >>> >> >> >> the input parameter stddeviation. The larger any of these
> values
> >>> >> >> >> is,
> >>> >> >> >> the more time v.kernel will need. Nevertheless, I think that
> the
> >>> >> >> >> 16+
> >>> >> >> >> hours are not correct. I tested with a vector with 3 million
> >>> >> >> >> points
> >>> >> >> >> for a grid with 2700 rows and 1087 columns, magnitudes larger
> >>> >> >> >> than
> >>> >> >> >> the
> >>> >> >> >> grid used by you. v.kernel completes in just over one minute.
> >>> >> >> >> > I posted my question about the 16+ hours at
> http://gis.stackexchange.com/questions/41058/how-do-i-compute-v-kernel-maps-in-less-than-16-hours/
> >>> >> >> >> > Bill Huber, who si apparently knowledgeable about kernel
> >>> >> >> >> > density
> >>> >> >> >> > calculations in general, posted a response, and he felt
> like a
> >>> >> >> >> > kernel
> >>> >> >> >> > density map shouldn't take much time at all. But digging
> more
> >>> >> >> >> > deeply,
> >>> >> >> >> > turns
> >>> >> >> >> > out he had come up with a kernel density calculation method
> >>> >> >> >> > over a
> >>> >> >> >> > decade
> >>> >> >> >> > ago using Fourier transforms. See
> >>> >> >> >> > http://www.directionsmag.com/features/convolution/129753and
> >>> >> >> >> > the
> >>> >> >> >> > next
> >>> >> >> >> > two
> >>> >> >> >> > articles linked to it (they are short articles). Apparently
> >>> >> >> >> > this
> >>> >> >> >> > transforms
> >>> >> >> >> > it from an O(n^2) problem to an O(n ln n) complexity
> problem.
> >>> >> >> >> The approach of Bill Huber is raster-based, not vector based,
> >>> >> >> >> making
> >>> >> >> >> some things easier, at the cost of precision. The coordinate
> >>> >> >> >> precision, however, is only needed for kernel functions other
> >>> >> >> >> than
> >>> >> >> >> uniform. In GRASS, you could get something like a raster-based
> >>> >> >> >> density
> >>> >> >> >> map by
> >>> >> >> >> - exporting the points with v.out.ascii
> >>> >> >> >> - re-importing the points with r.in.xyz method=n to get the
> >>> >> >> >> number
> >>> >> >> >> of
> >>> >> >> >> points per cell
> >>> >> >> >> - running a neighborhood analysis using a circular window with
> >>> >> >> >> r.neighbors method=sum -c
> >>> >> >> >> Optionally you could use the gauss option of r.neighbors to
> get
> >>> >> >> >> an
> >>> >> >> >> equivalent to v.kernel kernel=gaussian
> >>> >> >> >> HTH,
> >>> >> >> >> Markus M
> >>> >> >> >> > I inspected v.kernel's main.c
> http://trac.osgeo.org/grass/browser/grass/trunk/vector/v.kernel/main.c),
> >>> >> >> >> > and looks like v.kernel uses an output-centric method (using
> >>> >> >> >> > Bill's
> >>> >> >> >> > wording)
> >>> >> >> >> > of calculating the output, which seems like O(n^2)
> complexity.
> >>> >> >> >> > So I guess what I'm getting at is it appears to me that the
> >>> >> >> >> > algorithm
> >>> >> >> >> > behind
> >>> >> >> >> > GRASS GIS's v.kernel is straightforward but is a greedy
> >>> >> >> >> > algorithm
> >>> >> >> >> > (http://en.wikipedia.org/wiki/Greedy_algorithm), which is
> >>> >> >> >> > fine,
> >>> >> >> >> > but
> >>> >> >> >> > it
> >>> >> >> >> > make
> >>> >> >> >> > take a while to execute. Is this true?
> >>> >> >> >> > Is there not spatial indexing I could add to the dataset?
> I've
> >>> >> >> >> > done
> >>> >> >> >> > various
> >>> >> >> >> > Google searches on that and can't come up with anything
> clear.
> >>> >> >> >> > Aren
> >>> >> >> >> > _______________________________________________
> >>> >> >> >> > grass-user mailing list
> >>> >> >> >> > grass-user at lists.osgeo.org
> >>> >> >> >> > http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121206/d17d8c72/attachment-0001.html>
