[GRASS-user] i.landsat.toar unable to read metadata file
    Nikos Alexandris
    nik at nikosalexandris.net
    Wed Dec 12 22:15:38 PST 2012
(Apologies for not replying to the latest e-mail in this thread -- posting
from another machine with no access to past threads)
I tested the modified landsat_met.c code, provided by E. Jorge Tizado. It
works!  Yet, it fails somewhere else, e.g.:
# get toar
i.landsat.toar input_prefix=${BASE} output_prefix=${BASE}_toar
metfile=${BASE}_MTL.txt
ERROR: Unknown production date (defined by 'product_date')
It seems there are several modifications to the MET content structure.
Fortunately (?) two MET files are provided *currently* (at least I have seen
this in several L[MTE][457] scenes.
For example, an LT5 packed scene contains:
LT51810332008141MTI00_MTL.txt
LT51810332008141MTI00_MTLold.txt
The diff file looks like:
--- LT51810332008141MTI00_MTL.txt       2012-12-12 18:47:35.393026898 +0200
+++ LT51810332008141MTI00_MTLold.txt    2012-12-05 08:42:36.000000000 +0200
@@ -2,144 +2,140 @@
   GROUP = METADATA_FILE_INFO
     ORIGIN = "Image courtesy of the U.S. Geological Survey"
     REQUEST_ID = "0101212018233_00067"
-    LANDSAT_SCENE_ID = "LT51810332008141MTI00"
-    FILE_DATE = 2012-12-05T06:34:04Z
+    PRODUCT_CREATION_TIME = 2012-12-05T06:42:36Z
     STATION_ID = "EDC"
-    PROCESSING_SOFTWARE_VERSION = "LPGS_12.1.3"
-    DATA_CATEGORY = "NOMINAL"
+    LANDSAT5_XBAND = "1"
+    GROUND_STATION = "MTI"
+    LPS_PROCESSOR_NUMBER = 0
+    DATEHOUR_CONTACT_PERIOD = "0814108"
+    SUBINTERVAL_NUMBER = "01"
   END_GROUP = METADATA_FILE_INFO
   GROUP = PRODUCT_METADATA
-    DATA_TYPE = "L1T"
-    DATA_TYPE_L0RP = "TMR_L0RP"
+    PRODUCT_TYPE = "L1T"
     ELEVATION_SOURCE = "GLS2000"
-    OUTPUT_FORMAT = "GEOTIFF"
+    PROCESSING_SOFTWARE = "LPGS_12.1.3"
     EPHEMERIS_TYPE = "DEFINITIVE"
-    SPACECRAFT_ID = "LANDSAT_5"
+    SPACECRAFT_ID = "Landsat5"
     SENSOR_ID = "TM"
     SENSOR_MODE = "BUMPER"
+    ACQUISITION_DATE = 2008-05-20
+    SCENE_CENTER_SCAN_TIME = 08:40:46.1460440Z
     WRS_PATH = 181
-    WRS_ROW = 033
-    DATE_ACQUIRED = 2008-05-20
-    SCENE_CENTER_TIME = 08:40:46.1460440Z
-    CORNER_UL_LAT_PRODUCT = 39.86353
-    CORNER_UL_LON_PRODUCT = 25.17729
-    CORNER_UR_LAT_PRODUCT = 39.87362
-    CORNER_UR_LON_PRODUCT = 27.99044
-    CORNER_LL_LAT_PRODUCT = 37.92070
-    CORNER_LL_LON_PRODUCT = 25.22630
-    CORNER_LR_LAT_PRODUCT = 37.93012
-    CORNER_LR_LON_PRODUCT = 27.96380
-    CORNER_UL_PROJECTION_X_PRODUCT = 344100.000
-    CORNER_UL_PROJECTION_Y_PRODUCT = 4414200.000
-    CORNER_UR_PROJECTION_X_PRODUCT = 584700.000
-    CORNER_UR_PROJECTION_Y_PRODUCT = 4414200.000
-    CORNER_LL_PROJECTION_X_PRODUCT = 344100.000
-    CORNER_LL_PROJECTION_Y_PRODUCT = 4198500.000
-    CORNER_LR_PROJECTION_X_PRODUCT = 584700.000
-    CORNER_LR_PROJECTION_Y_PRODUCT = 4198500.000
-    REFLECTIVE_LINES = 7191
-    REFLECTIVE_SAMPLES = 8021
-    THERMAL_LINES = 7191
-    THERMAL_SAMPLES = 8021
-    FILE_NAME_BAND_1 = "LT51810332008141MTI00_B1.TIF"
-    FILE_NAME_BAND_2 = "LT51810332008141MTI00_B2.TIF"
-    FILE_NAME_BAND_3 = "LT51810332008141MTI00_B3.TIF"
-    FILE_NAME_BAND_4 = "LT51810332008141MTI00_B4.TIF"
-    FILE_NAME_BAND_5 = "LT51810332008141MTI00_B5.TIF"
-    FILE_NAME_BAND_6 = "LT51810332008141MTI00_B6.TIF"
-    FILE_NAME_BAND_7 = "LT51810332008141MTI00_B7.TIF"
-    GROUND_CONTROL_POINT_FILE_NAME = "LT51810332008141MTI00_GCP.txt"
-    REPORT_VERIFY_FILE_NAME = "LT51810332008141MTI00_VER.txt"
-    BROWSE_VERIFY_FILE_NAME = "LT51810332008141MTI00_VER.jpg"
-    METADATA_FILE_NAME = "LT51810332008141MTI00_MTL.txt"
-    CPF_NAME = "L5CPF20080401_20080630.16"
+    STARTING_ROW = 33
+    ENDING_ROW = 33
+    BAND_COMBINATION = "1234567"
+    PRODUCT_UL_CORNER_LAT = 39.8635274
+    PRODUCT_UL_CORNER_LON = 25.1772902
+    PRODUCT_UR_CORNER_LAT = 39.8736219
+    PRODUCT_UR_CORNER_LON = 27.9904391
+    PRODUCT_LL_CORNER_LAT = 37.9207012
+    PRODUCT_LL_CORNER_LON = 25.2262979
+    PRODUCT_LR_CORNER_LAT = 37.9301230
+    PRODUCT_LR_CORNER_LON = 27.9637968
+    PRODUCT_UL_CORNER_MAPX = 344100.000
+    PRODUCT_UL_CORNER_MAPY = 4414200.000
+    PRODUCT_UR_CORNER_MAPX = 584700.000
+    PRODUCT_UR_CORNER_MAPY = 4414200.000
+    PRODUCT_LL_CORNER_MAPX = 344100.000
+    PRODUCT_LL_CORNER_MAPY = 4198500.000
+    PRODUCT_LR_CORNER_MAPX = 584700.000
+    PRODUCT_LR_CORNER_MAPY = 4198500.000
+    PRODUCT_SAMPLES_REF = 8021
+    PRODUCT_LINES_REF = 7191
+    PRODUCT_SAMPLES_THM = 8021
+    PRODUCT_LINES_THM = 7191
+    BAND1_FILE_NAME = "LT51810332008141MTI00_B1.TIF"
+    BAND2_FILE_NAME = "LT51810332008141MTI00_B2.TIF"
+    BAND3_FILE_NAME = "LT51810332008141MTI00_B3.TIF"
+    BAND4_FILE_NAME = "LT51810332008141MTI00_B4.TIF"
+    BAND5_FILE_NAME = "LT51810332008141MTI00_B5.TIF"
+    BAND6_FILE_NAME = "LT51810332008141MTI00_B6.TIF"
+    BAND7_FILE_NAME = "LT51810332008141MTI00_B7.TIF"
+    GCP_FILE_NAME = "LT51810332008141MTI00_GCP.txt"
+    VER_REPORT_FILE_NAME = "LT51810332008141MTI00_VER.txt"
+    VER_BROWSE_FILE_NAME = "LT51810332008141MTI00_VER.jpg"
+    METADATA_L1_FILE_NAME = "LT51810332008141MTI00_MTLold.txt"
+    CPF_FILE_NAME = "L5CPF20080401_20080630_16"
   END_GROUP = PRODUCT_METADATA
-  GROUP = IMAGE_ATTRIBUTES
-    CLOUD_COVER = 10.00
-    IMAGE_QUALITY = 9
-    SUN_AZIMUTH = 127.92027132
-    SUN_ELEVATION = 63.07405928
-    GROUND_CONTROL_POINTS_MODEL = 1
-    GEOMETRIC_RMSE_MODEL = 3.741
-    GEOMETRIC_RMSE_MODEL_Y = 2.933
-    GEOMETRIC_RMSE_MODEL_X = 2.323
-    GROUND_CONTROL_POINTS_VERIFY = 1265
-    GEOMETRIC_RMSE_VERIFY = 0.160
-  END_GROUP = IMAGE_ATTRIBUTES
   GROUP = MIN_MAX_RADIANCE
-    RADIANCE_MAXIMUM_BAND_1 = 193.000
-    RADIANCE_MINIMUM_BAND_1 = -1.520
-    RADIANCE_MAXIMUM_BAND_2 = 365.000
-    RADIANCE_MINIMUM_BAND_2 = -2.840
-    RADIANCE_MAXIMUM_BAND_3 = 264.000
-    RADIANCE_MINIMUM_BAND_3 = -1.170
-    RADIANCE_MAXIMUM_BAND_4 = 221.000
-    RADIANCE_MINIMUM_BAND_4 = -1.510
-    RADIANCE_MAXIMUM_BAND_5 = 30.200
-    RADIANCE_MINIMUM_BAND_5 = -0.370
-    RADIANCE_MAXIMUM_BAND_6 = 15.303
-    RADIANCE_MINIMUM_BAND_6 = 1.238
-    RADIANCE_MAXIMUM_BAND_7 = 16.500
-    RADIANCE_MINIMUM_BAND_7 = -0.150
+    LMAX_BAND1 = 193.000
+    LMIN_BAND1 = -1.520
+    LMAX_BAND2 = 365.000
+    LMIN_BAND2 = -2.840
+    LMAX_BAND3 = 264.000
+    LMIN_BAND3 = -1.170
+    LMAX_BAND4 = 221.000
+    LMIN_BAND4 = -1.510
+    LMAX_BAND5 = 30.200
+    LMIN_BAND5 = -0.370
+    LMAX_BAND6 = 15.303
+    LMIN_BAND6 = 1.238
+    LMAX_BAND7 = 16.500
+    LMIN_BAND7 = -0.150
   END_GROUP = MIN_MAX_RADIANCE
   GROUP = MIN_MAX_PIXEL_VALUE
-    QUANTIZE_CAL_MAX_BAND_1 = 255
-    QUANTIZE_CAL_MIN_BAND_1 = 1
-    QUANTIZE_CAL_MAX_BAND_2 = 255
-    QUANTIZE_CAL_MIN_BAND_2 = 1
-    QUANTIZE_CAL_MAX_BAND_3 = 255
-    QUANTIZE_CAL_MIN_BAND_3 = 1
-    QUANTIZE_CAL_MAX_BAND_4 = 255
-    QUANTIZE_CAL_MIN_BAND_4 = 1
-    QUANTIZE_CAL_MAX_BAND_5 = 255
-    QUANTIZE_CAL_MIN_BAND_5 = 1
-    QUANTIZE_CAL_MAX_BAND_6 = 255
-    QUANTIZE_CAL_MIN_BAND_6 = 1
-    QUANTIZE_CAL_MAX_BAND_7 = 255
-    QUANTIZE_CAL_MIN_BAND_7 = 1
+    QCALMAX_BAND1 = 255.0
+    QCALMIN_BAND1 = 1.0
+    QCALMAX_BAND2 = 255.0
+    QCALMIN_BAND2 = 1.0
+    QCALMAX_BAND3 = 255.0
+    QCALMIN_BAND3 = 1.0
+    QCALMAX_BAND4 = 255.0
+    QCALMIN_BAND4 = 1.0
+    QCALMAX_BAND5 = 255.0
+    QCALMIN_BAND5 = 1.0
+    QCALMAX_BAND6 = 255.0
+    QCALMIN_BAND6 = 1.0
+    QCALMAX_BAND7 = 255.0
+    QCALMIN_BAND7 = 1.0
   END_GROUP = MIN_MAX_PIXEL_VALUE
   GROUP = PRODUCT_PARAMETERS
-    CORRECTION_GAIN_BAND_1 = "CPF"
-    CORRECTION_GAIN_BAND_2 = "CPF"
-    CORRECTION_GAIN_BAND_3 = "CPF"
-    CORRECTION_GAIN_BAND_4 = "CPF"
-    CORRECTION_GAIN_BAND_5 = "CPF"
-    CORRECTION_GAIN_BAND_6 = "INTERNAL_CALIBRATION"
-    CORRECTION_GAIN_BAND_7 = "CPF"
-    CORRECTION_BIAS_BAND_1 = "CPF"
-    CORRECTION_BIAS_BAND_2 = "CPF"
-    CORRECTION_BIAS_BAND_3 = "CPF"
-    CORRECTION_BIAS_BAND_4 = "CPF"
-    CORRECTION_BIAS_BAND_5 = "CPF"
-    CORRECTION_BIAS_BAND_6 = "CPF"
-    CORRECTION_BIAS_BAND_7 = "CPF"
+    CORRECTION_METHOD_GAIN_BAND1 = "CPF"
+    CORRECTION_METHOD_GAIN_BAND2 = "CPF"
+    CORRECTION_METHOD_GAIN_BAND3 = "CPF"
+    CORRECTION_METHOD_GAIN_BAND4 = "CPF"
+    CORRECTION_METHOD_GAIN_BAND5 = "CPF"
+    CORRECTION_METHOD_GAIN_BAND6 = "IC"
+    CORRECTION_METHOD_GAIN_BAND7 = "CPF"
+    CORRECTION_METHOD_BIAS = "CPF"
+    SUN_AZIMUTH = 127.9202713
+    SUN_ELEVATION = 63.0740593
+    OUTPUT_FORMAT = "GEOTIFF"
   END_GROUP = PRODUCT_PARAMETERS
-  GROUP = RADIOMETRIC_RESCALING
-    RADIANCE_MULT_BAND_1 = 0.766
-    RADIANCE_MULT_BAND_2 = 1.448
-    RADIANCE_MULT_BAND_3 = 1.044
-    RADIANCE_MULT_BAND_4 = 0.876
-    RADIANCE_MULT_BAND_5 = 0.120
-    RADIANCE_MULT_BAND_6 = 0.055
-    RADIANCE_MULT_BAND_7 = 0.066
-    RADIANCE_ADD_BAND_1 = -2.286
-    RADIANCE_ADD_BAND_2 = -4.288
-    RADIANCE_ADD_BAND_3 = -2.214
-    RADIANCE_ADD_BAND_4 = -2.386
-    RADIANCE_ADD_BAND_5 = -0.490
-    RADIANCE_ADD_BAND_6 = 1.182
-    RADIANCE_ADD_BAND_7 = -0.216
-  END_GROUP = RADIOMETRIC_RESCALING
+  GROUP = CORRECTIONS_APPLIED
+    STRIPING_BAND1 = "NONE"
+    STRIPING_BAND2 = "NONE"
+    STRIPING_BAND3 = "NONE"
+    STRIPING_BAND4 = "NONE"
+    STRIPING_BAND5 = "NONE"
+    STRIPING_BAND6 = "NONE"
+    STRIPING_BAND7 = "NONE"
+    BANDING = "N"
+    COHERENT_NOISE = "N"
+    MEMORY_EFFECT = "Y"
+    SCAN_CORRELATED_SHIFT = "Y"
+    INOPERABLE_DETECTORS = "N"
+    DROPPED_LINES = "N"
+  END_GROUP = CORRECTIONS_APPLIED
   GROUP = PROJECTION_PARAMETERS
+    REFERENCE_DATUM = "WGS84"
+    REFERENCE_ELLIPSOID = "WGS84"
+    GRID_CELL_SIZE_THM = 30.000
+    GRID_CELL_SIZE_REF = 30.000
+    ORIENTATION = "NUP"
+    RESAMPLING_OPTION = "CC"
     MAP_PROJECTION = "UTM"
-    DATUM = "WGS84"
-    ELLIPSOID = "WGS84"
-    UTM_ZONE = 35
-    GRID_CELL_SIZE_REFLECTIVE = 30.00
-    GRID_CELL_SIZE_THERMAL = 30.00
-    ORIENTATION = "NORTH_UP"
-    RESAMPLING_OPTION = "CUBIC_CONVOLUTION"
-    MAP_PROJECTION_L0RA = "NA"
   END_GROUP = PROJECTION_PARAMETERS
+  GROUP = UTM_PARAMETERS
+    ZONE_NUMBER = 35
+  END_GROUP = UTM_PARAMETERS
+  GROUP = GEOMETRIC_VERIFY
+    UL_QUAD_RMSE = 1.00
+    UR_QUAD_RMSE = 1.00
+    LR_QUAD_RMSE = 1.00
+    LL_QUAD_RMSE = 1.00
+    SCENE_RMSE = 1.00
+  END_GROUP = GEOMETRIC_VERIFY
 END_GROUP = L1_METADATA_FILE
 END
\ No newline at end of file
Thank you, Nikos
Type: text/x-patch
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121213/604386e7/attachment-0001.bin>
