[GRASS-user] movement direction surface in r.drain
Margherita Di Leo diregola at gmail.com
Wed Dec 19 06:42:15 PST 2012
Oops!
I've made another tentative, I've used r.mask to mask out the area within
the start polygon, but surprisingly I got the same result, as it seems that
the mask does not affect the result at all. IMHO this could be a bug of
r.mask (ok, separate topic), or is there any reason why r.mask shouldn't
affect it?
Thanks
On Wed, Dec 19, 2012 at 3:25 PM, Margherita Di Leo <diregola at gmail.com>wrote:
> Hi All,
> I have a friction map, a start polygon and an end polygon and would like
> to find the least cost path, meaning not a corridor but a thin line. To now
> I've tried both r.cost and r.walk and r.drain eventually, but the result of
> this latter
> r.drain input=friction at PERMANENT output=rdrain_out
> vector_points=start_line at PERMANENT
> is a path calculated *within* the start polygon (a closed line).
> I suppose this is because I don't provide a direction map to r.drain (I'm
> using GRASS 7). I read:
> If the *input* surface (a raster map layer) is a cumulative cost map
> generated by the *r.walk<http://grass.osgeo.org/grass70/manuals/r.walk.html>
> * or *r.cost <http://grass.osgeo.org/grass70/manuals/r.cost.html>* modules,
> the -d flag and a movement direction surface *"indir" *must be specified.
> I assume it's a kind of flow direction or aspect, but what is the physical
> meaning, and how can I calculate it? Could anyone please provide some
> further info.
> Thank you in advance
> Madi
> Margherita DI LEO
> Postdoctoral Researcher
> European Commission - DG JRC
> Institute for Environment and Sustainability (IES). Unit H03 – FRC
> Via Fermi, 2749
> I-21027 Ispra (VA) - Italy - TP 261
> Tel. +39 0332 78 3600
> margherita.di-leo at jrc.ec.europa.eu
> Disclaimer: The views expressed are purely those of the writer and may not
> in any circumstance be regarded as stating an official position of the
> European Commission.
Margherita DI LEO
Via Fermi, 2749
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121219/7597cbcb/attachment.html>
