[GRASS-user] Grass, Python, mapcalc
Paul Meems
bontepaarden at gmail.com
Fri Dec 28 03:16:20 PST 2012
Here I am again with some questions ;)
I'm now trying to use r.sun and r.mapcalc with Python to create my annual
solar radiation map.
I'm using the Python shell inside GRASS.
For testing purposes I start with 9 days.
The r.sun part seems to be working:
for x in range(1, 10, 1):
print "Working on day %d" % (x)
glob_rad = 'global' + str(x)
grass.run_command('r.sun', flags = 's', elevin = 'w001001 at temp', aspin
= 'aspect at temp', slopein = 'slope at temp', glob_rad = glob_rad, day = x)
I do have a question about parsing the --overwrite flag. How to do that.
Adding flags='s, --overwrite' or flags='s, -overwrite' gives a compile
error.
Now I try to combine the results of r.sun into 1 raster.
This is working:
if x == 2:
exp = 'sun = global1 at temp + global2 at temp'
print exp
grass.mapcalc(exp, quiet=False, verbose=False, overwrite=True)
This is also working:
if x == 2:
print exp
elif x > 2:
exp = 'sun = sun at temp + global' + str(x) + '@temp'
print exp
and produces this output:
sun = sun at temp + global3 at temp
sun = sun at temp + global4 at temp
sun = sun at temp + global5 at temp
sun = sun at temp + global6 at temp
sun = sun at temp + global7 at temp
sun = sun at temp + global8 at temp
sun = sun at temp + global9 at temp
But when I execute this using
Grass crashes completely.
Has this something to do with having the output file is the input file as
well?
If this is not allowed how can I combine all output files from r.sun into 1
raster?
Thanks,
Paul
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20121228/9a810c97/attachment.html>
