[GRASS-user] Grass, Python, mapcalc
S. Koukoulas (lists)
sotkouklistes at gmail.com
Fri Dec 28 06:02:31 PST 2012
Dear Paul,
having said all that for r.mapcalc, I wonder whether you really need
mapcalc. In your case,
couldn't you just use the * r.series * command with Sum (and perhaps
g.mlist can help you make a list of all the daily maps).
I think that it might be faster as well.
best,
sotiris
On 12/28/2012 03:08 PM, Paul Meems wrote:
> Thanks Sotiris,
> I've tried your suggestion but converted it to Python because I'm on
> Windows.
> This is my script:
> grass.run_command('g.mremove', rast = ('out*'))
> grass.mapcalc('sun=global1', quiet=False, verbose=False, overwrite=True)
> for x in range(2, 10, 1):
> exp = 'out=sun+global' + str(x)
> print exp
> grass.mapcalc(exp, quiet=False, verbose=False, overwrite=True)
> grass.run_command('g.rename', flag='o', rast = ('out','sun'))
> This doesn't result in the expected outcome.
> sun is equal to global1 and no values are added
> out is global1+global2 but is no more values are added. But mapcalc is
> called several times.
> I've tested this with:
> r.what --v -f -n input=global1 east_north=156287.225281,383024.737026
> r.what --v -f -n input=sun east_north=156287.225281,383024.737026
> r.what --v -f -n input=out east_north=156287.225281,383024.737026
> Not only am I a new user to GRASS but I'm also still a novice in
> Python. Most likely it is something in my script.
> If somebody has a different approach to get the solar radiation of a
> whole year I'm happy to try that.
> Thanks,
> Paul
> Date: Fri, 28 Dec 2012 14:36:15 +0200
> From: "S. Koukoulas (lists)" <sotkouklistes at gmail.com
> <mailto:sotkouklistes at gmail.com>>
> To: grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> Subject: Re: [GRASS-user] Grass, Python, mapcalc
> Message-ID: <50DD923F.806 at gmail.com <mailto:50DD923F.806 at gmail.com>>
> Content-Type: text/plain; charset=windows-1252
> To my experience with r.mapcalc you cannot do what yo do with
> programming languages... e.g. i=i+1 will not work directly.
> Instead you
> could try a more indirect way, something like (here is an example with
> bash shell script):
> #g.mremove rast=out* (to remove previous stuff, if needed)
> r.mapcalc sun=global1
> for a in ?seq 2 10?; do
> r.mapcalc out = sun + global$a
> g.rename --o rast=out,sun
> done
> basically the main idea is to use an intermediate map and then before
> the loop ends, pass it (with g.rename) to the map variable you want.
> There might be a more elegant way with python, but hopefully this
> shell
> script example might help you.
> HTH,
> sotiris
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
