[GRASS-user] r.drain problem when flow reach the border
Milton Cezar Ribeiro
miltinho.astronauta at gmail.com
Mon Dec 31 06:05:14 PST 2012
Hi Markus
Thanks for all your help.
Please, which svn command I need to run to get the daily trunk subversion?
best
miltinho
2012/12/31, Markus Metz <markus.metz.giswork at gmail.com>:
> Markus Metz wrote:
>> I am going to backport r.cost/r.walk/r.drain from 6.5 to 6.4.
> Done in r54470-1.
>> Happy new year,
>> Markus M
>>> best wishes
>>> miltinho
>>> 2012/12/30, Markus Metz <markus.metz.giswork at gmail.com>:
>>>> On Sun, Dec 30, 2012 at 8:59 PM, Milton Cezar Ribeiro
>>>> <miltinho.astronauta at gmail.com> wrote:
>>>>> Hi Rashad
>>>>> I tested with the trunk svn, but apparently it still not worked to me.
>>>>> Are you able to test with my datased?
>>>>> https://www.yousendit.com/download/UW16RE9zTkxlM1JBSXNUQw
>>>> What are the commands you used? I found
>>>> r.drain input=custo_aux_cost output=custo_aux_cost_drain
>>>> vector_points=map_target_pt
>>>> You need to also provide a direction map with the indir option of
>>>> r.drain.
>>>> Markus M
>>>>> Thanks!
>>>>> miltinho
>>>>> 2012/12/27, Mohammed Rashad <mohammedrashadkm at gmail.com>:
>>>>>> Hi Milton,
>>>>>> I think this fix will solve the problem[0]. For elevation data there
>>>>>> might
>>>>>> be cases where no path exists ie, only single pixel is the selected
>>>>>> path.
>>>>>> I
>>>>>> had tested it by myself and it worked.
>>>>>> Please apply the patch and let me know.
>>>>>> If any problem comes in compilation or doing r.drain let me know. It
>>>>>> will
>>>>>> be great if you can share the test data you are using in case not
>>>>>> working
>>>>>> after applying the patch
>>>>>> [0] http://trac.osgeo.org/grass/attachment/ticket/1840/r.drain.diff
>>>>>> [1] http://trac.osgeo.org/grass/attachment/ticket/1840/drain.c
>>>>>> On Thu, Dec 27, 2012 at 2:31 AM, Milton Cezar Ribeiro <
>>>>>>> Hi Mohamed and Markus
>>>>>>> Mohamed, thanks for your reply, I will wait for a solution within
>>>>>>> GRASS
>>>>>>> Markus, thanks for your reply,. Sorry but I disagree a tiny bit,
>>>>>>> because is expected that between a source and target I will find a
>>>>>>> solution with the Least Cost path. Do you think that is there any
>>>>>>> situation where a least cost between source and target will not be
>>>>>>> found? Maybe if other software provide the soluction, although is
>>>>>>> not
>>>>>>> the bestest option, I prefere receive one complete output than a
>>>>>>> broken one.
>>>>>>> Happy new year!
>>>>>>> miltinho
>>>>>>> 2012/12/23, Markus Metz <markus.metz.giswork at gmail.com>:
>>>>>>> > On Sun, Dec 23, 2012 at 7:07 PM, Milton Cezar Ribeiro
>>>>>>> >> Dear all,
>>>>>>> >> I am running a least cost path analysis combining r.cost and
>>>>>>> >> r.drain.
>>>>>>> >> But on some cases, when the least cost path between source and
>>>>>>> >> target
>>>>>>> >> reach the border of my map, r.drain stop on that position, and
>>>>>>> >> target
>>>>>>> >> point isn´t reached.
>>>>>>> > This is correct because at the borders, the direction can not be
>>>>>>> > determined, the path could lead out of the current region, you can
>>>>>>> > not
>>>>>>> > tell.
>>>>>>> > Running on other softwares the algorithms the
>>>>>>> >> source and target is connected using edges without problem.
>>>>>>> > If in doubt, I would call it a bug in that other software.
>>>>>>> >> Any hint are welcome.
>>>>>>> > Try to expand the current region
>>>>>>> > Markus M
>>>>>>> Miltinho - mcr at rc.unesp.br
>>>>>>> Laboratório de Ecologia Espacial e Conservação - LEEC
>>>>>>> Depto de Ecologia - UNESP - Rio Claro
>>>>>>> Av. 24A, 1515- Bela Vista
>>>>>>> 13506-900 Rio Claro, SP, Brasil
>>>>>>> Fone: +55 19 3526-9647 (office) 19 3526-9680 (lab)
>>>>>>> Cel: 19 9853-3220 / 19 9853-5430
>>>>>>> Depto Ecologia http://www.rc.unesp.br/ib/ecologia/
>>>>>>> PG ECO & BIODIV
>>>>>>> http://www.rc.unesp.br/ib/ecologia/posbiodiversidade/index.php
>>>>>>> CV
>>>>>>> http://buscatextual.cnpq.br/buscatextual/visualizacv.do?id=K4792988H6&mostrarNroCitacoesISI=true&mostrarNroCitacoesScopus=true
>>>>>>> Google citations
>>>>>>> http://scholar.google.com/citations?user=OWX_2eAAAAAJ
>>>>>>> _______________________________________________
>>>>>>> grass-user mailing list
>>>>>>> grass-user at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>>>>>> Regards,
>>>>>> Rashad
>>>>> PG ECO & BIODIV
>>>>> CV
>>>>> Google citations http://scholar.google.com/citations?user=OWX_2eAAAAAJ
>>> PG ECO & BIODIV
>>> CV
PG ECO & BIODIV http://www.rc.unesp.br/ib/ecologia/posbiodiversidade/index.php
CV http://buscatextual.cnpq.br/buscatextual/visualizacv.do?id=K4792988H6&mostrarNroCitacoesISI=true&mostrarNroCitacoesScopus=true
