[GRASS-user] bug in r.pi.nlm add-on module
    Hamish
    hamish_b at yahoo.com
    Wed Feb  1 17:06:49 EST 2012
Martin Wegmann wrote:
> > I encountered a bug in an add-on module, r.pi.nlm
> > (gdb) r.pi.nlm input=landclass96 keyval=5 output=test
> --o
> > Starting program:
> > Program received signal SIGSEGV, Segmentation fault.
> > (gdb) bt full
> >         min = 1000000
> >         max = 1000000
> >         span = 0
> >         index = -2147483648
> > in func.c:
> >     span = max - min;
> >     c = min / span;
> >         index = floor(RESOLUTION *
> > (map[i] - min) / span);
> >         ^^^^^^--- negative
> >     Then the subsequent values[index] crashes.
> min=max so span=0. the resulting divide by 0
> causes the index to go to infinity.
I notice MinMax() in func.c starts its for loop
at i=1 instead of 0, perhaps that is a bug?
Hamish
