[GRASS-user] ps.map rotatecolumn argument
Vincent Bain
bain at toraval.fr
Sat Feb 4 12:19:42 EST 2012
Hi list,
Has anyone experienced the ability of ps.map's vpoints instruction to
choose from a rotatecolumn to orient symbols on a map ?
Here's the concerned part of my ps.map instruction file :
vpoints arrow
layer 2
color black
eps /usr/local/grass-6.4.2svn/etc/paint/patterns/cross_normal.eps
rotatecolumn angle
where r=1
size 1
end
In my case, map arrow contains about 50 points but ps.map only displays
a few ones at correct angle. The database field is integer, angles are
specified ccw from east.
The display of these rotated symbols is correct in wxGUI window.
Digging in the postscript output one can see rotation is not aways
considered where it should, e.g.
BeginEPSF
640.00000 496.30000 translate
0.00000 rotate # here it should be sth like 25.00000 rotate
1.00000 1.00000 scale
%BeginDocument: SITEEPSF4
SITEEPSF4
%EndDocument
EndEPSF
Any idea of what I do wrong ?
Vincent.
