[GRASS-user] Re: grass-user Digest, Vol 70, Issue 7
Shane Litherland litherland-farm at bigpond.com
Sat Feb 4 22:27:55 EST 2012
Hi Aldo, Martin
In last week I to did some work with adding scale/north to a map.
using 6.4.svn (a couple of days behind update at time of post).
With python wx GUI
Found similar to Aldo, where adding scalebar seemed to be a 'once-off'
option, couldn't click on it etc to edit. using icon on toolbar to open
'add scalebar' again didn't seem to help, I may have even crashed the
display/GRASS at one point by clicking around too much on that... but at
time was busy to print the map so did what I had to do to get job done
and continued.
Other bits I noticed, was if I chose to use print icon, and sent to pdf,
much of the map was a black box, with scalebar in top-left of black box
but positioned on right place of map. Black box though seemed to be this
huge bit of extra space associated with scalebar.
printing/exporting to .png image did not result in this black box.
Also, if I made a scalebar but then zoomed map in/out, the scalebar
stayed the same size and in the same position within the display window,
not in the same position relative to the map.
So whatever calculates the scalebar does not refresh if zoom is used
after creation of the scalebar.
Have not tried any of this back in tcltk GUI
Any aspects here worth verifying and adding to a bug report, or putting
in as their own bugs?
Aldo - let me know what bug # you have for putting yours in.
regards,
shane.
> Message: 3
> Date: Sat, 4 Feb 2012 12:09:47 +0100
> From: "Aldo Clerici" <aldo.clerici at unipr.it>
> Subject: [GRASS-user] Problems with histogram and scalebar in wxpython
> 	GUI	(GRASS6.4.2RC3)
> To: <grass-user at lists.osgeo.org>
> Message-ID: <059f01cce32d$81c6e1b0$8554a510$@clerici at unipr.it>
> Content-Type: text/plain; charset="us-ascii"
> Dear GRASSusers and developers,
> I'm using GRASS6.4.2RC3 under Fedora 16 and I'm having problems with the
> wxpython GUI.
> 1) In the 'Create histogram of raster map' function, the style pie and the
> Color for text and axes options are not working.
> The options  run fine on the tcltk GUI and in command line mode.
> 2) In the 'Add scalebar and north arrow', the scale can be modified only
> once and the option can't be re-entered nor the scale can't be deleted.
> Also in this case there are no problems with the tcltk GUI.
> Bugs or something wrong in my Python?
> Many thanks in advance
> A. Clerici
> Parma University
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120204/a55a85be/attachment-0001.html
> Message: 4
> Date: Sat, 4 Feb 2012 12:44:23 +0100
> 	GUI	(GRASS6.4.2RC3) (supplement)
> Message-ID: <05aa01cce332$574b62d0$05e22870$@clerici at unipr.it>
> In GRASS6.4.0 USB version I have the same problems with the histogram, but
> "add scalebar" works fine.
> A.      Clerici
> URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120204/03696e42/attachment-0001.html
> Message: 5
> Date: Sat, 4 Feb 2012 13:36:48 +0100
> From: Martin Landa <landa.martin at gmail.com>
> Subject: Re: [GRASS-user] Problems with histogram and scalebar in
> 	wxpython GUI	(GRASS6.4.2RC3)
> To: Aldo Clerici <aldo.clerici at unipr.it>
> Cc: grass-user at lists.osgeo.org
> Message-ID:
> 	<CA+Ei1Oe25CoqmckGLQFAqXiLBFj-07eY-7SBo8b14R072K8qdw at mail.gmail.com>
> Content-Type: text/plain; charset=ISO-8859-1
> Hi,
> 2012/2/4 Aldo Clerici <aldo.clerici at unipr.it>:
> right, wxGUI histogramming tool happily ignores any d.histogram
> settings expect map name, see [1]. Please fill a bug report, I would
> assume that this bug will be fixed for 6.4.3 (where wxGUI code base
> will change).
> Martin
> [1] http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/histogram.py#L341
