[GRASS-user] Null or 0?
Daniel Victoria
daniel.victoria at gmail.com
Sun Feb 5 04:22:29 EST 2012
Hi Andre,
On raster algebra, operations using null will return null while operations
with 0 behaves like expected. Ex:
12 x null = null
12 x 0 = 0
Null is interesting to use on areas you don't have / want to represent,
like an ocean...
Hope it helps
Daniel
On Feb 5, 2012 12:03 AM, "ALT SHN" <i.geografica at alt-shn.org> wrote:
> Hello,
> I have a technichal doubt. I used* v.to.rast.constant *to tranform a line
> vector layer to raster. This meant i have a raster with NULL values.
> The output raster is to be used in map algebra operations.
> So my question is: Is it advisable to set the Null cells to 0? I know
> r.calc works with NULL values, and I know that NULL is not the same as 0,
> however I never understood what difference does it make if any. Considering
> these two scenarios what do I win and what do I loose?
> Any enlightening will be very aprecciated!
> Thanks,
> André Mano
> Associação Leonel Trindade
> SOCIEDADE DE HISTÓRIA NATURAL
> Apartado 25 2564-909 Torres Vedras Portugal
> Sede e Biblioteca: rua Cavaleiros da Espora Dourada, 27A 2560 Torres Vedras
> Laboratório de Paleontologia e Paleoecologia: Polígono Industrial do Alto
> do Ameal 2565-641 Ramalhal
> http://alt-shn.blogspot.com
> www.alt-shn.org
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120205/542e8d4f/attachment.html
