[GRASS-user] Re: winGrass, ODBC and MS Access database
Christine
geo.guide at web.de
Sun Feb 5 14:45:25 EST 2012
Hi Martin,
"v.external -l" reports ODBC format:
Available OGR Drivers:
ODBC (rw): ODBC
_______________________________
(Sun Feb 05 19:12:08 2012)
v.in.ogr dsn=ODBC:Testdatenbank -l
ERROR 1: Unable to initialize ODBC connection to DSN for
Testdatenbank,
[Microsoft][ODBC Microsoft Access Driver] Datenbank
'(unbekannt)' konnte nicht geöffnet werden. Entweder wird
die Datenbank nicht von Ihrer Anwendung erkannt, oder die
Datei ist beschädigt.
ERROR: Unable to open data source <ODBC:Testdatenbank>
(Sun Feb 05 19:12:09 2012) Command finished (0 sec)
[Sorry for german error reporting - though I have turned all settings to
English GRASS returns some comments in german:
[Microsoft][ODBC Microsoft Access Driver] Database
'(unknown)' could not be opended. Either database is not recognized by your
application, or file is damaged.]
Actually I can open this database "Testdatenbank" with QGIS and gvSIG and I
have no reason to assume data corruption. Have also connected to the
database with "db.connect --verbose driver=odbc database=Testdatenbank".
Do I miss anything ? First connecting, then calling the database somehow or
have I to undertake another step in between ?
thanks + regards, Christine
View this message in context: http://osgeo-org.1560.n6.nabble.com/Re-winGrass-ODBC-and-MS-Access-database-tp4356636p4367516.html
Sent from the Grass - Users mailing list archive at Nabble.com.
