[GRASS-user] How to compile r.example
Luisa Peña
luisapena1979 at gmail.com
Mon Feb 6 04:25:53 EST 2012
Hi Markus
Already done that. I have compiled and installed from source code. So my
problem is to add and compile functions such as r.example.
What do I have to do?
Thanks
Luisa
2012/2/3 Markus Neteler <neteler at osgeo.org>
> On Fri, Feb 3, 2012 at 4:36 PM, Luisa Peña <luisapena1979 at gmail.com>
> wrote:
> > Greetings
> > I'm running GRASS6.4.2 in a Linux machine and when I try to compile
> > r.example I get this:
> > lp at earth1:~/r.example$ make
> > Makefile:10: ../../../include/Make/Module.make: No such file or directory
> > make: *** No rule to make target `../../../include/Make/Module.make'.
> Stop.
> You need to run "configure" first in the main source code directory.
> See for details for example
> http://grass.osgeo.org/wiki/Compile_and_Install#Generic_Compilation_and_installation_procedure
> Markus
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120206/24668f56/attachment.html
