[GRASS-user] Python - GRASS module output, r.univar
Johannes Radinger JRadinger at gmx.at
Mon Feb 6 09:30:17 EST 2012
I try to write a python script for GRASS6.5 including a
WHILE loop. A certain calculation step (iterative) should
be performed until there are only NULL values in a raster.
I am not sure what is the best way to find out if there are
only NULL cells. I tried it with r.univar which gives no result
when there are only NULL cells in a raster (and no result is acutally
also a result :)). But how can I get that value to variable
in the python script? In the wiki there is something stated about
the grass.script.raster_info (e.g. for the max value):
max = grass.raster_info(inmap)['max']
Is there a special function also for the counts of cells? Or how
can I parse the result of r.univar to a python variable?
My loop:
while (count > 0):
    count = number of !isnull of raster A
What would you do? Suggestions are mostly welcome :)
cheers,
Johannes
NEU: FreePhone 3-fach-Flat mit kostenlosem Smartphone!
Jetzt informieren: http://www.gmx.net/de/go/freephone/
