[GRASS-user] r.sunmask (position) and r.shaded.relief
Hamish
hamish_b at yahoo.com
Wed Feb 8 03:01:11 EST 2012
Paolo wrote:
> > What is in short, the difference between the two commands?
Markus N:
> They are completely different.
> r.sunmask calculated the sun position for a given
> date-time, optionally writing out
> a sun cast shadow map (not shaded!)
note that r.sun output maps can be used to good effect with
the d.shadedmap module to make a "more-correct" version of a
typical r.shaded.relief image.
e.g. http://bambi.otago.ac.nz/hamish/grass/screenshots/deep_cove_rsun.jpg
perhaps only worth it if you already have the r.sun result in
hand.
> r.shaded.relief generates a shaded relief from a DEM to be
> used as background for other maps.
(you can place the sun's angle in the sky at whatever angle you
like, but the effect is purely a visual one; r.sunmask uses a
real solar movement algorithm and outputs in shadow/out of
shadow data map)
Hamish
ps- debian has a site set up where you can upload a screenshot
of any package it hosts. I wonder what it would take to set up
a similar thing for GRASS? so people could easily upload a screen
shot of any particular module in action.
http://screenshots.debian.net/package/grass
http://debshots.workaround.org/trac/
(a javascript/Pylons [python web frameworks] dev volunteer
would be needed)
