[GRASS-user] An error in GRASS-7 manual
Andres Kuusk andres at aai.ee
Thu Feb 9 09:18:30 EST 2012
Hi!
>>>> ERROR: Sorry, <map> is not a valid parameter
>>>> ERROR: Required parameter <vector> not set
> Perhaps you need to recompile the code if you did it yourself
I see!
I am still using GRASS-7  r48844 and everything works fine.
This minor discrepancy between the code and manual is not a problem.
Thanks for your advice!
Andres
> AH, I got it: you are using GRASS 6 while reading the GRASS 7 manual..
> the parameter name
> changed! So please read here instead for GRASS 6:
> http://grass.osgeo.org/grass64/manuals/html64_user/v.what.rast.html
> Hope this helps,
> Markus
