[GRASS-user] Cost Path
ALT SHN
i.geografica at alt-shn.org
Fri Feb 10 15:30:49 EST 2012
@ Roberto
Thank you for the hint. It's a nice way arround for a future purpose.
The friction map I am using was build from various inputs, one of them the
DEM (slope). So, if I understood right, using r.walk would be redundant
beacause slope and altitude are already considered in the friction map.
Best Regards,
André
2012/2/8 Roberto Marzocchi <roberto.marzocchi at gmail.com>
> I have resolved with:
> r.walk -k elevation=your_dtm friction=your_friction output=*walkout*start_points=A stop_points=B
> afterwards
> r.drain -c input=*walkout* output=drainout vector_points=B
> perhaps it is need a filling of the dtm and also of walkout map in order
> to avoid aq loop effect
> All the best,
> Roberto
> 2012/2/7 Moritz Lennert <mlennert at club.worldonline.be>
>> On 07/02/12 14:39, ALT SHN wrote:
>>> Hello list,
>>> I have a raster obtained through r.mapcalc whose cells values represent
>>> friction or cost.
>> I suppose that is friction per cell.
>> To finish my study I'm lacking one final step - calculate the least cost
>>> path!
>>> How do I do it? I've tried r.cost but the result is not wat I expected -
>>> My desired output is just a line from A to B, crossing the least valued
>>> cells.
>> Use r.cost with the coordinate of (or the vector or raster file
>> containing) A as start point. Then r.drain with B as starting point.
>> Moritz
>> ______________________________**_________________
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/**mailman/listinfo/grass-user<http://lists.osgeo.org/mailman/listinfo/grass-user>
Associação Leonel Trindade
SOCIEDADE DE HISTÓRIA NATURAL
Apartado 25 2564-909 Torres Vedras Portugal
Sede e Biblioteca: rua Cavaleiros da Espora Dourada, 27A 2560 Torres Vedras
Laboratório de Paleontologia e Paleoecologia: Polígono Industrial do Alto
do Ameal 2565-641 Ramalhal
http://alt-shn.blogspot.com
www.alt-shn.org
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120210/5d320397/attachment.html
