[GRASS-user] v.clean break
    Paolo Craveri
    pcraveri at gmail.com
    Tue Feb 14 09:30:50 EST 2012
Hi all.
I am referring to an earlier similar problem.
In GRASS 6.4.1, spearfish dataset, I just tried this:
r.contour in=elevation.dem step=500 out=contour --overwrite
echo "VERTI:
L 2 1
591140 4917821
604188 4918841
1 1" | v.in.ascii out=arc format=standard --overwrite
v.patch in=arc,contour out=lines --overwrite
v.clean in=lines tool=break out=linesbreak thresh=0 --overwrite
but in this case v.clean doesn't make any break (no node is created at
the intersections)
If I export and re-import through a shapefile   v.clean works perfectly:
v.out.ogr dsn=pippo.shp in=lines
v.in.ogr dsn=pippo.shp out=arcsfromshp
v.clean in=arcsfromshp tool=break out=arcsfromshpbreak thresh=0 --overwrite
why?
Paolo C.
