[GRASS-user] copy elements from user-mapset to PERMANENT
Johannes Radinger
JRadinger at gmx.at
Wed Feb 15 05:00:26 EST 2012
I tried to copy a vector from my user mapset into
the PERMANENT mapset of the same location with g.copy.
g.copy vect=Treene_GK at Treene,Treene_simple at PERMANENT region=region_treene at Treene,region_Treene at PERMANENT
Illegal filename. Character <@> not allowed.
<Treene_simple at PERMANENT> is an illegal file name
<region_Treene at PERMANENT> is an illegal file name
(Wed Feb 15 10:57:31 2012) Command finished (0 sec)
Maybe that is not the correct command..is there a simple way
to perform that copy? Or do I need to export/import the files?
So far as I understand I can read the PERMAMENT maps from all
mapsets in that location...Thats why I'd like to have certain
basic maps in there
Best regards...
Johannes
NEU: FreePhone 3-fach-Flat mit kostenlosem Smartphone!
Jetzt informieren: http://www.gmx.net/de/go/freephone/
