[GRASS-user] copy elements from user-mapset to PERMANENT
Johannes Radinger
JRadinger at gmx.at
Wed Feb 15 06:10:32 EST 2012
> Hi,
> 2012/2/15 Johannes Radinger <JRadinger at gmx.at>:
> > I tried to copy a vector from my user mapset into
> > the PERMANENT mapset of the same location with g.copy.
> you have write access only for the current mapset. In other words, you
> need to switch to PERMANENT and call `g.copy` from the target mapset.
> > g.copy vect=Treene_GK at Treene,Treene_simple at PERMANENT
> region=region_treene at Treene,region_Treene at PERMANENT
> > Illegal filename. Character <@> not allowed.
> > <Treene_simple at PERMANENT> is an illegal file name
> > <region_Treene at PERMANENT> is an illegal file name
> > (Wed Feb 15 10:57:31 2012) Command finished (0 sec)
> g.mapset PERMANENT
Thank you... of course I have to change the mapset...don't
know why I missed that step before...:(
cheers,
johannes
> > Maybe that is not the correct command..is there a simple way
> > to perform that copy? Or do I need to export/import the files?
> Well, the error message is not clear enough...
> Martin
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
NEU: FreePhone 3-fach-Flat mit kostenlosem Smartphone!
Jetzt informieren: http://www.gmx.net/de/go/freephone/
