[GRASS-user] Re: grass and palsar processing
maning sambale
emmanuel.sambale at gmail.com
Wed Feb 15 06:52:51 EST 2012
Thanks markus for this.
I added an initial workflow for the ENVI tutorial I attended my goal
is to "port" this to GRASS. Most of the process is already available
in the pdf Alexander provided.
However, I'm having difficulty importing images from the K&C mosaic
product [0]. In the training I attended the mosaic product was
converted to GTiff using ASF MapReady [1]. According to ASF MapReady
the format is CEOS L1.
I tried using r.in.gdal and r.in.bin (based on the pdf) but I cannot
import the K&C mosaic
[0] http://www.eorc.jaxa.jp/ALOS/en/kc_mosaic/kc_mosaic.htm
[1] http://www.asf.alaska.edu/downloads/software_tools/mapready/version_history
On Sat, Feb 11, 2012 at 7:54 AM, Markus Neteler <neteler at osgeo.org> wrote:
> Hi,
> I am almost there:http://grass.osgeo.org/wiki/Radar_data_processing
> only imagemagick currently fails to make the thumbnails after debian
> upgrade.will check asap and upload the missing files.
> On Fri, Feb 10, 2012 at 7:43 PM, Alexander Muriy <amuriy at gmail.com> wrote:
>> Also there is PDF http://gis-lab.info/forum/download/file.php?id=2370,
>> copied from http://www.safe.iis.u-tokyo.ac.jp/, about SAR & GRASS.
> thanks, added on the Wiki page.
> Markus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
