[GRASS-user] GRASS-6.4.2 dependencies
Stuart Edwards
sedwards2 at cinci.rr.com
Fri Feb 24 08:57:40 EST 2012
Deleting and reinstalling took care of the problem -
Thanks for all your work keeping this sorted !
Stu
On Feb 23, 2012, at 7:46 PM, William Kyngesburye wrote:
> For some reason FreeType lately has been bumping the library version on minor updates. 2.4.6 is ver 14 and 2.4.4 is ver 13. The latest 2.4.8 is ver 15, so it's odd that yours is coming up as ver 13.
> Have you installed the FreeType framework in the past? Try deleting the FreeType.framework from /Library/Frameworks and reinstalling 2.4.8.
> On Feb 23, 2012, at 12:06 PM, Stuart Edwards wrote:
>> Hi -
>> Moving on to 6.4.2 ..... (see my post earlier today re: GRASS 7)
>> Same problem - error at startup reported as:
>> GRASS 6.4.2svn (oh_s_3402):~ > 3D view mode: dlopen(/Applications/GRASS-6.4.app/Contents/MacOS/lib/libgrass_display.6.4.2svn.dylib, 10): Library not loaded: /Library/Frameworks/FreeType.framework/Versions/2.4/FreeType
>> Referenced from: /Applications/GRASS-6.4.app/Contents/MacOS/lib/libgrass_display.6.4.2svn.dylib
>> Reason: Incompatible library version: libgrass_display.6.4.2svn.dylib requires version 14.0.0 or later, but FreeType provides version 13.0.0
>> Again, prevents opening of d.rast
>> Same question - how to update to v 14.0.0 (but of what?)
>> Stu_______________________________________________
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "The beast is actively interested only in now, and, as it is always now and always shall be, there is an eternity of time for the accomplishment of objects."
> - the wisdom of Tarzan
