[GRASS-user] how to install gstat with grass 6 support?
Vishal Mehta
vishalm1975 at gmail.com
Fri Feb 24 13:56:22 EST 2012
Markus,
i do have the grass6_dev package. is that different from grass-dev?
FYI these are the messages i get after
*./configure --with-grass6=/usr/local/grass-6.5.svn*
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for ranlib... ranlib
checking for a BSD-compatible install... /usr/bin/install -c
checking how to run the C preprocessor... gcc -E
checking for egrep... grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for function prototypes... yes
checking for an ANSI C-conforming const... yes
checking for flex... flex
checking for yywrap in -lfl... yes
checking lex output file root... lex.yy
checking whether yytext is a pointer... yes
checking for bison... bison -y
checking stat.h usability... no
checking stat.h presence... no
checking for stat.h... no
checking getopt.h usability... yes
checking getopt.h presence... yes
checking for getopt.h... yes
checking whether time.h and sys/time.h may both be included... yes
checking for working memcmp... yes
checking for vprintf... yes
checking for _doprnt... no
checking for strstr... yes
checking for strtod... yes
checking for strtol... yes
checking for popen... yes
checking for drand48... yes
checking for gettimeofday... yes
checking for snprintf... yes
checking for vsnprintf... yes
checking for getopt_long... yes
checking for getopt... yes
checking whether byte ordering is bigendian... no
checking for main in -lncurses... yes
checking for gdImagePng in -lgd... no
checking for gdImageGif in -lgd... no
checking for main in -lnetcdf... yes
checking for GDALAllRegister in -lgdal... yes
checking for QRfactor in -lmeschach... no
checking for MgetVersion in -lcsf... no
checking for G_gisinit in -lgrass_gis... no
checking for G_gisinit in -lgis... no
checking for main in -lgsl... no
configure: creating ./config.status
config.status: creating makefile
config.status: creating src/makefile
config.status: creating doc/tex/makefile
config.status: creating src/config.h
config.status: src/config.h is unchanged
does that help troubleshoot?
Vishal
On Thu, Feb 23, 2012 at 11:49 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Fri, Feb 24, 2012 at 1:13 AM, Vishal Mehta <vishalm1975 at gmail.com>
> wrote:
> > I'm tring to install gstat (version 2.4.5) with grass 6 support enabled,
> on
> > a Ubuntu machine
> > I've grass-6.5.svn installed in :
> > i used this configure line to build gstat :
> This looks fine. But I assume that you need to additionally install the
> grass-dev package. Perhaps yet missing on your machine?
> Markus
Vishal K. Mehta, PhD
Scientist
Stockholm Environment Institute - US
133 D St Suite F
Davis CA 95616
www.sei-us.org
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120224/221bad48/attachment.html
