[GRASS-user] How to create 500m DEM from 90m DEM
SGW00412 at nifty.com
Sun Jan 1 23:22:57 EST 2012
Dear Markus and all
> Of course - the vector is just used to find the target area of
> the raster map.
Yes, I understood it. Thanks.
So, at web site grass manual, I found 'r.resamp.interp' command.
When I would like to create this under same datum and projection
with only difference resolutions, then may I use this command ?
for example;
g.region rast=<srtm_raster> -p
...0:00:03
g.region res=0:00:17 -p
r.resamp.interp input=<srtm_raster> output=<srtm_raster_500m>
r.to.vect input=<srtm_raster_500m> output=<....>
Best
Yasuo shimada:Japan weather association.
Markus Neteler <neteler at osgeo.org>さん:
> 2012/1/1 <SGW00412 at nifty.com>:
> > Dear Micha and all
> > Thank you for useful suggestions!
> > I studied new vector extent with v.in.region, and interpolation should be
not
> > vector but raster.
> the raster map.
> See also
> http://grass.osgeo.org/grass64/manuals/html64_user/r.proj.html
> -> v.in.region method
> Best
> Markus
