[GRASS-user] Connecting table
Bulent Arikan bulent.arikan at gmail.com
Tue Jan 3 09:50:55 EST 2012
Dear List,
I rasterized a centroid and ran 'r.univar', whose extended stats are saved
as a text file. Then, I ran 'v.db.addtable' to create a second layer in the
attribute table of the centroid and I had columns added in this second
layer using 'v.db.addcol'. I want GRASS to upload values from the text file
but I am not sure how to perform this task.
Is there a shorter way of creating a second layer and uploading values from
the text file or what should I do next so that the columns in the second
layer will be populated using the text file I have?
Thank you for your time.
GRASS 6.5 svn on Snow Leopard
BÜLENT
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120103/3b0924d4/attachment.html
