[GRASS-user] Connecting table
    Bulent Arikan
    bulent.arikan at gmail.com
    Fri Jan  6 07:31:17 EST 2012
OK! That makes sense now. I have one last standing issue about this. It
seems that the second layer I created using 'v.db.addtable' (after setting
the dbf to SQL and importing a centroid –vector– map) has a column for CAT
but it does not have a number. I checked the book to make sure and it says
it should have a number and it does not have to be continuous from the
first layer.
I tried assigning a CAT# using 'v.category' and 'v.db.connect' but I still
do not see a number in CAT column. I think I should have a number there so
that my "...WHERE cat = ...." argument makes sense. Any ideas how to
correct this?
Thank you,
Bulent
On Thu, Jan 5, 2012 at 12:27 PM, Micha Silver <micha at arava.co.il> wrote:
> On 01/05/2012 10:49 AM, Bulent Arikan wrote:
> Hi,
>  I really would like to learn more about the SQL command-based operations
> in GRASS. To summarize: I have created a new mapset where the driver is set
> to SQL. I have created second layers for all of my centroids (the tables in
> the second layers have a different name like "Db_runivar" ). I used
> 'v.db.addtable' to have GRASS create columns to upload the results from
> extended statistics of r.univar text files (e.g., Db_runivar.txt) for each
> centroid.
>  Now, I have been trying to get 'db.execute' to work. One suggestion was
> that I use a loop for automated updating (I am assuming that I have to
> type this in the Terminal):
>  > while read l; do \
>     col=`echo $l | cut -d= -f1`; val=`echo $l | cut -d= -f2`; \
>     sqlite3 sqlite.db "UPDATE centroid SET ${col}=${val} ;"; \
> > done < univar.txt
>  I came up with a statement (below) by looking at the manual in
> 'r.univar' to create an SQL command file:
>   sed -e '1d' Dogubayazit_runivar.txt | awk -F'l' '{print "UPDATE
> Dogubayazit_runivar SET non_null_cells = "$2", null_cells = "$3", min =
> "$4", max = "$5", range = "$6", mean = "$7", mean_of_abs = "$8", stddev =
> "$9", variance = "$10", coeff_var = "$11", sum = "$12", sum_abs = "$13",
> first_quart = "$14", median = "$15", third_quart = "$16", perc_90  = "$17"
> WHERE cat = "$1";"}'
> The above will create a list of update statements, one for each row in the
> runivar.txt file. You can't feed db.execute a list of statements, only one
> at a time. So you'll have to dump the output of the above command into an
> intermediary file, then use the db.execute "input" parameter to specify
> that file of SQL commands.
> It might be worth noting that if you have many UPDATE's, then doing them
> one by one with an individual call to the database each time might take a
> bit of time. In this case, going back to sqlite, you could wrap all the
> UPDATE statements between a BEGIN...COMMIT clause, then feed that file to
> db.execute (or directly to sqlite), and it will open one connection, and
> push all the updates at once. For many 1000's of rows this would probably
> be much faster.
>  that can be used in 'db.execute' but I am getting a syntax error:
>  DBMI-SQLite driver error:
> Error in sqlite3_prepare():
> near "sed": syntax error
> ERROR: Error while executing: 'sed -e '1d' ............
> What seems to be the problem?
> Thank you for your time.
>  Bulent
> On Wed, Jan 4, 2012 at 9:16 AM, Micha Silver <micha at arava.co.il> wrote:
>>  On 01/03/2012 10:44 PM, Bulent Arikan wrote:
>> Thank you! This seems to be an interesting solution to the problem
>> especially because it involves changing the driver from DBF to SQLITE. I
>> ended up using 'v.rast.stats', which adds columns for extended statistics
>> and uploads values all at once. The only thing is: data are recorded as
>> part of the same layer (i.e., Layer 1). So, I cheated!
>>  Yes, v.rast.stats is definitely the way to go if you want raster
>> univariate statistics pushed into a polygon vector.
>>  However, I started trying your method. I created a new mapset to use
>> sqlite and copied some vector maps from a mapset where default driver is
>> DBF. I defined SQLITE as the new driver in the new mapset using
>> 'db.connect'
>> (driver=sqlite, database='$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db', no
>> flags checked). Then I wanted to use 'v.db.connect' for a vector map but I
>> cannot select table name etc. I also tried just using 'v.db.connect' but I
>> still cannot see anything under Table. So. I am confused about how to
>> define a new driver in a mapset.
>>  I do as follows:
>> eval `g.gisenv`
>> (This creates the environment variables for GISDBASE, etc.)
>> Now:
>> db.connect driv=sqlite database=$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db
>> Next:
>> g.copy vect=old,new
>> to create a new copy of the original vector. The original will still have
>> its attrib table as dbf. THe new copy will have an sqlite based attribute
>> table.
>> Now you can do:
>> v.db.addcol <new_vector> col="..., ..." .
>> BTW, I think that v.rast.stats will automatically create the needed
>> columns .
>> Cheers,
>> Micha
>>  Thank you again,
>>  Bulent
>> On Tue, Jan 3, 2012 at 9:13 PM, Micha Silver <micha at arava.co.il> wrote:
>>>  On 01/03/2012 04:50 PM, Bulent Arikan wrote:
>>> Dear List,
>>>  I rasterized a centroid and ran 'r.univar', whose extended stats are
>>> saved as a text file. Then, I ran 'v.db.addtable' to create a second layer
>>> in the attribute table of the centroid and I had columns added in this
>>> second layer using 'v.db.addcol'. I want GRASS to upload values from the
>>> text file but I am not sure how to perform this task.
>>>  Is there a shorter way of creating a second layer and uploading values
>>> from the text file or what should I do next so that the columns in the
>>> second layer will be populated using the text file I have?
>>>  I'm not sure about a shorter way, but here's an option:
>>> First setup your mapset to save attributes to sqlite.
>>> > v.db.connect centroid driver=sqlite database=....
>>> Now add the columns which will accept r.univar values to the sqlite
>>> table:
>>> > v.db.addcol centroid col="n double, null_cells double, cells double,
>>> min double, max double, range double, mean double, mean_of_abs double,
>>> stddev double, variance double, coeff_var double, sum double"
>>> Run r.univar on your raster, putting results into a text file
>>> > r.univar your_rast -g  > univar.txt
>>> Now do this loop to update values for the centroid:
>>> > while read l; do \
>>> > done < univar.txt
>>> Assuming you want to run this for several centroids/areas, you'll
>>> probably want to add a WHERE clause to the UPDATE statement so as to put
>>> values for only one certain row (centroid).
>>> HTH, Micha
>>>  GRASS 6.5 svn on Snow Leopard
>>> BÜLENT
>>>  This mail was received via Mail-SeCure System.
>>> grass-user mailing listgrass-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/grass-user
>>> Micha Silver
>>> GIS Consultant, Arava Development Co.http://www.surfaces.co.il
>> BÜLENT ARIKAN, PhD
>> Senior Research Fellow
>> Research Center for Anatolian Civilizations
>> Koç University
>> İstiklal Caddesi No: 181 Merkez Han
>> Beyoğlu - ISTANBUL
>> TURKEY
>> 34433
>> (+ 90) 212-393-6036 <%28%2B%2090%29%20212-393-6036>
BÜLENT ARIKAN, PhD
Koç University
Beyoğlu - ISTANBUL
TURKEY
34433
(+ 90) 212-393-6036
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120106/788a7aa5/attachment-0001.html
