[GRASS-user] problems with colors resulting of an image fusion
    Moritz Lennert
    mlennert at club.worldonline.be
    Fri Jan  6 11:42:30 EST 2012
Hi everyone,
I have some troubles with image fusion through IHS transformation of a
Landsat image. Using d.rgb to display the resulting r,g,b channels gives
completely different colors than the original d.rgb on the 30,20,10
Landsat channels.
On this image:
http://geog-pc40.ulb.ac.be/grass/landsat_fusion.png
You see the original d.rgb on the upper left, the panchromatic channel
on the lower left and the result of the IHS transformation on the lower
right.
All channels have a grey.eq color table.
The image
http://geog-pc40.ulb.ac.be/grass/landsat_fusion2.png
shows the same, but zoomed-in, showing that the fusion seems to have
worked (i.e. the resulting image has higher resolution).
Does anybody have an idea of might be the problem ?
Moritz
