[GRASS-user] Set default cell type to FCELL?
Rainer M Krug
r.m.krug at gmail.com
Wed Jan 11 03:45:50 EST 2012
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 11/01/12 04:49, Glynn Clements wrote:
> Rainer M Krug wrote:
>> What I would like to do is tho change the default type from CELL
>> to FCELL - i.e. whenever a new raster is created, it will
>> *always* and *automatically* be saved in a FCELL raster, even if
>> it only contains integer values, and not in a CELL raster.
> This isn't possible.
Pitty - but makes sense.
> If a module generates a CELL map, it's invariably because it's
> performing the calculations using integers. Converting the final
> result to floating-point wouldn't help; if the integer
> calculations overflow, converting the result to floating-point
> won't "undo" the overflow.
Good point - so I have to change my approach.
> Some modules will generate either integer or floating-point output
> depending upon the type of the inputs.
Yes - I am referring mainly to r.mapcalc with the overflow - so I can
do the conversion in the formula.
>> so
>> oldmap * 1
>> results in a raster of the same type as oldmap,
> Arithmetic operations on mixed types promote to the lesser type to
> the greater type, where CELL < FCELL < DCELL.
I assume the "to the lesser type" should be deleted? So they promote
to the higher type?
>> where
>> oldmap * 1.0
>> would result in a FCELL?
> Actually, it will result in DCELL. r.mapcalc follows C syntax:
> floating-point literals are double precision unless suffixed with
> an "f", so "oldmap * 1.0f" will result in FCELL (unless oldmap is
> DCELL).
OK.
> But float(oldmap) or double(oldmap) do the same thing but avoid the
> gratuitous multiply operation.
Agreed - and I am using them - the * 1 was just a (not very good) example.
> Also:
> 1. If you are having issues with overflow, you need to promote
> values before calculations, e.g. "float(x) * y". Using "float(x *
> y)" will result in x*y overflowing, then the overflowed value will
> be converted.
Very good point - have to go through my code again.
> 2. Single precision (FCELL) only has a 24-bit mantissa, so integers
> greater than 2^24 (16777216) cannot always be represented exactly.
> Double precision (DCELL) has a 53-bit mantissa.
So I will go to DCELL and double().
Thanks,
things are much clearer now.
Rainer
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax : +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer at krugs.de
Skype: RMkrug
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAk8NTD4ACgkQoYgNqgF2egpwQACfakWPvtlsaKBMBSbn10uNMLAR
PssAn0xf5gE+TSOujix1N2qs0Qw1aqoT
=4tuq
-----END PGP SIGNATURE-----
