[GRASS-user] How to rescale
Moritz Lennert
mlennert at club.worldonline.be
Wed Jan 11 07:51:58 EST 2012
On 09/01/12 20:42, leonidas wrote:
> I created a raster using *r.grow.distance*
> I need to rescale that file to a scale 0-255 but in reverse order where high
> values in distance file will be converted in low values to the rescaled
> file.
> I'm using the following command:
>r.recode input=dist_file output=recoded_file <<EOF
>0:133000:255:0
>EOF
[BTW: I don't know how you formatted your mail, but for me the above
three lines showed as:
> But the output file has a range 60-255
> What's going wrong?
> Is there any better way to do that?
Are you sure that 133000 is the max of your map in the region you are
using ? Be aware that r.info gives the info for the whole map, ignoring
region settings and a possible mask. You can use r.univar or r.stats to
see the max in the current region/mask.
Moritz
