[GRASS-user] r.sum from maps in different mapset
Rainer M Krug r.m.krug at gmail.com
Fri Jan 13 03:32:03 EST 2012
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 12/01/12 22:39, Hamish wrote:
> mapname at othermapset
> use 'g.mapsets -s' to select mapsets to put in the search path (in
> which case you can skip the @othermapset part, but it don't hurt to
> explicitly add that)
> mapsets not in the current search path can still be accessed by
> @othermapset.
Thanks Hamish - that is exactly what I was looking for (the @) and it
is now working nicely.
I initially tried it as well, but it did not work - but I tried to
access a map which did not exist in the other mapset - shame on me.
Thanks,
Rainer
> Hamish
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel :       +33 - (0)9 53 10 27 44
Cell:       +33 - (0)6 85 62 59 98
Fax :       +33 - (0)9 58 10 27 44
Fax (D):    +49 - (0)3 21 21 25 22 44
email:      Rainer at krugs.de
Skype:      RMkrug
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAk8P7AMACgkQoYgNqgF2egrLtACcD4dB/I+St4NFlmE3Z9ryhlxx
/1wAn1v/BPOH4cJ48PxAMnTdSpf2g1VO
=FFpx
-----END PGP SIGNATURE-----
