[GRASS-user] winGRASS i.ortho.photo
Sat Jan 14 18:59:05 EST 2012
João Fonte wrote:
> I'm working with Windows7 and I need to use the i.ortho.photo module in
> winGRASS. Is there any way that winGRASS natively support the required
> xterm for the** i.ortho.photo module without been necessary to install
> after and configure Cygwin (which is quite complicated!)?
No. The photo.2image and photo.2target modules require XDRIVER, which
isn't available in native Windows builds.
Unless someone figures out how to make display drivers work natively,
the only option is to use a Cygwin build of GRASS.
