[GRASS-user] weird results from v.distance's to_angle
Hamish
hamish_b at yahoo.com
Mon Jan 16 00:08:25 EST 2012
Moritz wrote:
> While I'm not sure which of the to_angle descriptions I
> prefer (in your version it is not unambiguously clear where
> the angle is measured as I image that the 'to' feature is a
> line, not a line segment)
However we word it, I expect adding a small graphic to the help
page is ultimately going to do the best job of explaining it.
> Here would be my go for both of them:
> "to_along;distance to the nearest point on 'from' feature
> along linear feature, measured from 'start' point of that
> linear feature;"
sounds fine. (it really is from the start node of that line not the
start of that line segment, right?) maybe add a note about
v.build.polylines to the help page?
> "to_angle;angle of linear feature at the point nearest to
> point/centroid in 'from' map, counterclockwise from positive
> x axis, in radians, which is between -PI and PI inclusive;"
one of my goals was to have it be a brief description (goal < 60 chars!)
not a full paragraph, which is why I tried to remove as many
words as possible without letting it get too ambiguous.
so:
* "point/centroid in " isn't strictly needed
* "positive x axis" -> "+x axis"
* counterclockwise -> CCW
* "which is " -> ""
* In this context Pi is a proper name not a C macro or acronym, so
the "I" is lowercased.
otherwise '--help' on the command line looks crappy with the line-wrap.
perhaps extending the indentation code could help that, but the art of
concise technical writing is always good to practice. :-)
the main bug was that it's not the angle of the line _to_ the nearest
point, it's the angle _of the line_ at the nearest point. as long as that's
clear+correct I'm not too worried about the exact wording of it, have fun.
cheers,
Hamish
