[GRASS-user] Measuring Distance Along a Line
Maris Nartiss maris.gis at gmail.com
Fri Jan 20 02:18:36 EST 2012
Hello,
if You are interested to get similar functionality like r.profile does
for raster, there's a GRASS add-on v.profile, that allows to profile
vector point and line maps. Area support is not implemented.
Input for v.profile should be a map with a single transect line (or
single line should be selected with SQL)  or Northing, Easting value
list representing line and a map with points/lines. Module output will
be a list of feature (point within specified tolerance, line crossing)
distance from the start of profile line + feature attribute data.
If You need some help, let me know.
Maris.
http://grass.osgeo.org/wiki/GRASS_AddOns#v.profile
http://trac.osgeo.org/grass/browser/grass-addons/grass6/vector/v.profile
2012/1/18 Rich Shepard <rshepard at appl-ecosys.com>:
>  I have a map with a couple of transect lines that intersect points on a
> separate map. I want to measure the distance from one end of each transect
> line to the point which it overlays. While I thought there was a v. module
> to do this, I'm not seeing it. If it's v.distance, I don't see how to apply
> that module to measuring a distance along one line interactively.
>  Clue stick needed.
> Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
