[GRASS-user] Re: GRASS EXAMPLE
Hrachya Astsatryan
hrach at sci.am
Sat Jan 21 15:50:37 EST 2012
After the compilation, r.example gives "Segmentation fault"
[root at wn1 r.example]# /usr/local/grass-6.4.2svn/bin/r.example
Segmentation fault
On 1/21/12 11:03 PM, Martin Landa wrote:
> Hi,
> 2012/1/21 Hrachya Astsatryan<hrach at sci.am>:
>> I have installed successfully the Grass via elgis.repo (see below)
>> [root at wn1 grass-6.4.1]# yum list|grep grass|more
>> grass.x86_64 6.4.1-2.el5.elgis
>> installed
>> grass-devel.x86_64 6.4.1-2.el5.elgis
>> installed
>> grass-libs.x86_64 6.4.1-2.el5.elgis
>> installed
>> So What should I do else?
> well, GRASS 6.4.2 has been released yet, you could try to compile
> GRASS [1] on your own or to wait for 6.4.2 release. Quick solution
> could be to copy `Make` directory from SVN [2] to your `include`
> directory. Anyway `grass-devel` seems to be incomplete in this repo.
> Martin
> [1] http://trac.osgeo.org/grass/wiki/BuildingOnUnix
> [2] http://svn.osgeo.org/grass/grass/tags/release_20110412_grass_6_4_1/include/Make/
Hrachya Astsatryan
Head of HPC Laboratory,
Institute for Informatics and Automation Problems,
National Academy of Sciences of the Republic of Armenia
1, P. Sevak str., Yerevan 0014, Armenia
t: 374 10 284780
f: 374 10 285812
e: hrach at sci.am
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120122/08f1e48d/attachment.html
