[GRASS-user] Re: GRASS EXAMPLE
Hrachya Astsatryan hrach at sci.am
Sun Jan 22 10:07:21 EST 2012
On 1/22/12 12:57 AM, Sören Gebbert wrote:
> Hi Hrachya,
> make sure you started a valid grass session before you execute any
> grass command.
Sorry I am beginner in GRASS, what do you mean "start a valid grass
session"?
Thank yu in advanced,
Hrach
> Does only r.example segfault or any other command too?
> Best
> Soeren
> Hint:
> I would avoid to use the root account when working with grass ....
> 2012/1/21 Hrachya Astsatryan<hrach at sci.am>:
>> After the compilation, r.example gives "Segmentation fault"
>> [root at wn1 r.example]# /usr/local/grass-6.4.2svn/bin/r.example
>> Segmentation fault
>> On 1/21/12 11:03 PM, Martin Landa wrote:
>> Hi,
>> I have installed successfully the Grass via elgis.repo (see below)
>> [root at wn1 grass-6.4.1]# yum list|grep grass|more
>> grass.x86_64                             6.4.1-2.el5.elgis
>> installed
>> grass-devel.x86_64                       6.4.1-2.el5.elgis
>> installed
>> grass-libs.x86_64                        6.4.1-2.el5.elgis
>> installed
>> So What should I do else?
>> well, GRASS 6.4.2 has been released yet, you could try to compile
>> GRASS [1] on your own or to wait for 6.4.2 release. Quick solution
>> could be to copy `Make` directory from SVN [2] to your `include`
>> directory. Anyway `grass-devel` seems to be incomplete in this repo.
>> Martin
>> [1] http://trac.osgeo.org/grass/wiki/BuildingOnUnix
>> [2]
>> http://svn.osgeo.org/grass/grass/tags/release_20110412_grass_6_4_1/include/Make/
>> Hrachya Astsatryan
>> Head of HPC Laboratory,
>> Institute for Informatics and Automation Problems,
>> National Academy of Sciences of the Republic of Armenia
>> 1, P. Sevak str., Yerevan 0014, Armenia
>> t: 374 10 284780
>> f: 374 10 285812
>> e: hrach at sci.am
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
Hrachya Astsatryan
t: 374 10 284780
f: 374 10 285812
e: hrach at sci.am
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120122/8f4f441b/attachment.html
