Fwd: [GRASS-user] Problem in Compiled AddOns in Ubuntu 11.10
(grass-6.4.2svn)
Marcello Benigno
benigno.marcello at gmail.com
Sun Jan 29 19:20:20 EST 2012
Hi Neteler and Hamish,
I Compiled again after up the svn and the problem still the same. Please,
take a look:
GRASS 6.4.2svn (spearfish60):~/grassdata/spearfish60/user1 > g.extension
extension=v.surf.icw operation=add
Fetching <v.surf.icw> from GRASS-Addons SVN (be patient)...
A v.surf.icw/v.surf.icw
A v.surf.icw/description.html
A v.surf.icw/qgis-toolbox
A v.surf.icw/qgis-toolbox/default.qgc.diff
A v.surf.icw/qgis-toolbox/v.surf.icw.1.png
A v.surf.icw/qgis-toolbox/v.surf.icw.2.png
A v.surf.icw/qgis-toolbox/v.surf.icw.qgm
A v.surf.icw/Makefile
U v.surf.icw
Checked out revision 50537.
Compiling <v.surf.icw>...
/usr/local/grass-6.4.2svn/include/Make/Grass.make:422: warning: overriding
commands for target
`/home/marcello/grassdata/spearfish60/user1/.tmp/marcello-gis/29085.0/dist.i686/bin'
/usr/local/grass-6.4.2svn/include/Make/Grass.make:413: warning: ignoring
old commands for target
/usr/local/grass-6.4.2svn/include/Make/Script.make:47: warning: overriding
commands for target `install'
/usr/local/grass-6.4.2svn/include/Make/Rules.make:90: warning: ignoring old
mkdir -p
mkdir -p
/home/marcello/grassdata/spearfish60/user1/.tmp/marcello-gis/29085.0/dist.i686/include/grass
mkdir -p
/home/marcello/grassdata/spearfish60/user1/.tmp/marcello-gis/29085.0/dist.i686/etc
mkdir -p
/home/marcello/grassdata/spearfish60/user1/.tmp/marcello-gis/29085.0/dist.i686/driver
mkdir -p
/home/marcello/grassdata/spearfish60/user1/.tmp/marcello-gis/29085.0/dist.i686/driver/db
mkdir -p
/home/marcello/grassdata/spearfish60/user1/.tmp/marcello-gis/29085.0/dist.i686/fonts
if [ ! -d
/home/marcello/grassdata/spearfish60/user1/.tmp/marcello-gis/29085.0/dist.i686/scripts
]; then mkdir -p
/home/marcello/grassdata/spearfish60/user1/.tmp/marcello-gis/29085.0/dist.i686/scripts;
fi
/usr/bin/install -c v.surf.icw
/home/marcello/grassdata/spearfish60/user1/.tmp/marcello-gis/29085.0/dist.i686/scripts/v.surf.icw
make htmlscript scriptstrings
make[1]: Entering directory
`/home/marcello/grassdata/spearfish60/user1/.tmp/marcello-gis/29085.0/v.surf.icw'
commands for target
make
/home/marcello/grassdata/spearfish60/user1/.tmp/marcello-gis/29085.0/dist.i686/docs/html/v.surf.icw.html
HTMLSRC=/home/marcello/grassdata/spearfish60/user1/.tmp/marcello-gis/29085.0/dist.i686/scripts/v.surf.icw
make[2]: Entering directory
commands for target
if [
"/home/marcello/grassdata/spearfish60/user1/.tmp/marcello-gis/29085.0/dist.i686/scripts/v.surf.icw"
!= "" ] ; then
GISRC=/home/marcello/grassdata/spearfish60/user1/.tmp/marcello-gis/29085.0/dist.i686/demolocation/.grassrc64
GISBASE=/usr/local/grass-6.4.2svn
PATH="/home/marcello/grassdata/spearfish60/user1/.tmp/marcello-gis/29085.0/dist.i686/bin:$PATH"
LD_LIBRARY_PATH="/home/marcello/grassdata/spearfish60/user1/.tmp/marcello-gis/29085.0/dist.i686/bin:/usr/local/grass-6.4.2svn/lib:/usr/local/grass-6.4.2svn/lib"
LC_ALL=C
--html-description < /dev/null | grep -v '</body>\|</html>' >
v.surf.icw.tmp.html ; true ; fi
/usr/local/grass-6.4.2svn/tools/mkhtml.sh v.surf.icw ; mkdir -p
; /usr/bin/install -c -m 644 v.surf.icw.tmp.html
; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ;
if [ $? -ne 0 ] ; then /usr/bin/install -c -m 644 $file
; fi done 2> /dev/null ; true
make[2]: Leaving directory
PATH=/home/marcello/grassdata/spearfish60/user1/.tmp/marcello-gis/29085.0/dist.i686/bin:$PATH
LD_LIBRARY_PATH="/usr/local/grass-6.4.2svn/lib:/usr/local/grass-6.4.2svn/lib"
g.parser -t v.surf.icw | sed s/\"/\\\\\"/g | sed 's/.*/_("&")/' >
/usr/local/grass-6.4.2svn/locale/scriptstrings/v.surf.icw_to_translate.c ;
true
/bin/sh: cannot create
/usr/local/grass-6.4.2svn/locale/scriptstrings/v.surf.icw_to_translate.c:
Directory nonexistent
make[1]: Leaving directory
make mancmd
commands for target
make
/home/marcello/grassdata/spearfish60/user1/.tmp/marcello-gis/29085.0/dist.i686/man/man1/v.surf.icw.1
MANSRC=/home/marcello/grassdata/spearfish60/user1/.tmp/marcello-gis/29085.0/dist.i686/docs/html/v.surf.icw.html
commands for target
mkdir -p
GRASS_PERL=/usr/bin/perl VERSION_NUMBER=6.4.2svn sh
/usr/local/grass-6.4.2svn/tools/g.html2man
1
make[2]: ***
[/home/marcello/grassdata/spearfish60/user1/.tmp/marcello-gis/29085.0/dist.i686/man/man1/v.surf.icw.1]
Error 127
make[1]: *** [mancmd] Error 2
make: ***
[/home/marcello/grassdata/spearfish60/user1/.tmp/marcello-gis/29085.0/dist.i686/scripts/v.surf.icw]
Error 2
ERROR: Compilation failed, sorry. Please check above error messages.
Regards,
*Marcello Benigno B. de Barros Filho*
Prof. do Curso Superior de Tecnologia em Geoprocessamento - IFPB
Mestre em Ciências Geodésicas e Tecnologias da Geoinformação - UFPE
http://profmarcello.blogspot.com
http://about.me/marcello.benigno
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20120129/efc8ef35/attachment-0001.html
