[GRASS-user] GRASS and the Python geospatial modules (Shapely, PySAL, ...)
gene martin.laloux at gmail.com
Sun Jul 1 10:57:53 PDT 2012
1) Sorry but I do not know where to put this part in the wiki
2) Finally, switching from Shapely geometries to GRASS GIS vector is not
very complicated
 - *A single line in Shapely*:
>>>  line.wkt
'LINESTRING (122286.3249999999970896 120453.2514999999984866,
123404.2657999999937601 119175.6049000000057276, 123510.7363999999943189
117445.4584000000031665, 124362.5007999999943422 115875.0178000000014435)'
            or
>>> list(line.coords)
[(122286.325, 120453.2515), (123404.26579999999, 119175.60490000001),
(123510.73639999999, 117445.4584), (124362.50079999999, 115875.0178)]
- therefore with Grass temporary files:
1) *creation of a vector layer:*
>>> grass.read_command("v.edit",tool="create",map="testfromshapely")
2) *creation of the temporary file*
>>> tempfile = grass.tempfile()
>>> pfish = open(tempfile, 'w')
>>> print>> pfish, "L", str(len(line.coords)), "1"
>>> for i in line.coords:
...      print>> pfish,str(i[0]),str(i[1])
>>> print>> pfish, "1", 1
>>> pfish.close()
3) *the resulting temporary file*
L 4 1
122286.325 120453.2515
123404.2658 119175.6049
123510.7364 117445.4584
124362.5008 115875.0178
1 1
4) *adding the temporary file to the vector layer:*
>>> grass.run_command("v.edit", input=tempfile, flags="n", tool="add",
>>> map="testfromshapely", snap="node", thresh="1")
1 features added
Building topology for vector map <testfromshapely>...
Registering primitives...
1 primitives registered
4 vertices registered
Number of nodes: 2
5) *you can also create a point layer with the vertices*
>>> grass.read_command("v.edit",tool="create",map="points_shapely")
>>> for index, i in enumerate(line.coords):
...      print>> pfish,"P 1 1"
...      print>> pfish,str(i[0]),str(i[1])...      print>> pfish, "1 " +
str(index+1)...
>>> pfish.close()
6) *the resulting temporary file*
P 1 1
1 1
P 1 1
1 2
P 1 1
1 3
P 1 1
1 4
7) *adding the temporary file to the vector layer:*
>>> map="points_shapely", snap="node", thresh="1")
4 features added
Building topology for vector map <points_shapely>...
4 primitives registered
Number of nodes: 4
Results
http://osgeo-org.1560.n6.nabble.com/file/n4985178/resultshapely_grass.jpg
You can use all the functions of Shapely and add the results to the
associated table , if you want:
>>> line.length
5217.6727474454265
etc.
You can also transform the lines in a Graph with the networkx module and the
distances between the points as weight (see
http://doc.lizardsystem.nl/libs/nens/_modules/nens/geom.html
http://doc.lizardsystem.nl/libs/nens/_modules/nens/geom.html )
>>> from shapely.geometry import Point
>>> import networkx as nx
1) *creation of a graph*
>>> G = nx.Graph()
>>> from shapely.geometry.point import Point
>>> points = [i for i in line.coords]
2) *adding the points to the graph with the distance between the points as
weight*
>>> for D, A in zip(points, points[1:]):
...       G.add_edge(D, A, {'weight': Point(D).distance(Point(A))})
3)* results*
>>> G.number_of_edges()
3
>>> G.number_of_nodes()
4
>>> G.adjacency_list()
[[(123510.73639999999, 117445.4584)], [(123510.73639999999, 117445.4584),
(122286.325, 120453.2515)], [(123404.26579999999, 119175.60490000001),
(124362.50079999999, 115875.0178)], [(123404.26579999999,
119175.60490000001)]]
and return the results in GRASS GIS with the same temporary files method.
View this message in context: http://osgeo-org.1560.n6.nabble.com/GRASS-and-the-Python-geospatial-modules-Shapely-PySAL-tp4985075p4985178.html
Sent from the Grass - Users mailing list archive at Nabble.com.
