[GRASS-user] Invalid region and coordinates when trying to reproject.
Markus Metz markus.metz.giswork at gmail.com
Sun Jul 1 23:54:58 PDT 2012
On Sun, Jul 1, 2012 at 9:17 AM, Marcello Gorini <gorini at gmail.com> wrote:
> Dear all,
> After importing a netCDF file and correcting its bounds using
> r.region so that it spans from -180/180 instead of 0/360, a tried to
> reproject it in the way I always do, following the GRASS book.
> I use v.in.region to get the region as a vector, v.proj in a mercator
> location and then g.region to the projected vector, before applying
> r.proj to my raster.
What are the extents of the vector in latlon before projecting into
the mercator location? Note that regions spanning 180 degrees
longitude or more can not be reprojected to mercator locations due to
mathematical constraints.
> Now, the new grid is within accepted bounds, but the error persists and
> the result of v.info of the projected region is
>  | Layer:           rbd
>  | Mapset:          BRASIL
>  | Location:        GEBCO_MERCATOR
>  | Database:        /home/marcello/grassdata
>  | Title:
>  | Map scale:       1:1
>  | Map format:      native
>  | Name of creator: marcello
>  | Organization:
>  | Source date:     Sun Jul  1 07:55:56 2012
>  |   Type of Map:  vector (level: 2)
>  |   Number of points:       0               Number of areas:      0
>  |   Number of lines:        0               Number of islands:    0
>  |   Number of boundaries:   1               Number of faces:      0
>  |   Number of centroids:    1               Number of kernels:    0
>  |   Map is 3D:              No
>  |   Number of dblinks:      0
>  |         Projection: x,y
>  |               N:               inf    S:    -4605.12989327
>  |               E:               inf    W: -20037508.34278924
This inf looks very suspicious, the latlon vector extents very
probably too large and could not be represented in the projection of
the target location.
Markus M
>  |   Digitization threshold: 0
>  |   Comments:
> Obviously, something is wrong with the N and E coordinates.
> Any ideas?
> Thanks in advance.
> Marcello.
> the problem is with broken cellsize value, resulting in a
> latitude beyond the north pole.
>>> 0.0083333337679505 * 18000 - 60
> ans =      90.000007823109
> which is > 90.
> it seems that whatever software exported it (don't be afraid to
> name names :) was holding or calculating the resolution with
> single-precision floating point numbers but exporting it as if
> it were a double-precision number. So the second half the number
> is inexact jibberish.
> Edit the cell size back to 0.008333333 (no small feat with a
> 3.7gb file, even for vi) and it'll work.
> Importing with GDAL would give the same illegal-north latitude
> result, although r.in.gdal now has a '-l' flag to reset the
> northern boundary into something legal (after which you Must
> repair it to the real value with r.region), although you could
> get the same effect by editing the header to lie about the
> cellsize or southern value to get it to fit into legal lat/lon,
> then again use r.region to set the bounds exactly. (the
> resolution as seen with r.info should end up exactly at 30 arc-
> sec; bypass the built in failsafe checks at your own risk)
> But the real solution is to get the software that created it
> to not export broken files.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
