[GRASS-user] [GRASS-dev] new pan sharpening script added to grass7 addons
Markus Neteler
neteler at osgeo.org
Tue Jul 3 15:13:04 PDT 2012
On Tue, Jul 3, 2012 at 7:30 PM, Michael Barton <michael.barton at asu.edu> wrote:
> I just uploaded a new script that--i.pansharpen--allows the user to select
> from several different algorithms to do pan sharpening of multispectral
> imagery. By default, it will run on multiple cores (you can select serial
> processing with the -s flag). I'm considering the script ultimately as an
> enhancement of and replacement for the i.fusion.brovey script (which uses
> only the Brovey pan sharpening algorithm) in trunk. So testing would be very
> welcome. There is a pretty comprehensive help file that accompanies it.
Very nice, Michael!
I made a quick test with Brovey (and added a related example to the docs),
works well.
If users could test please with other data... i.fusion.brovey should
be replaced then.
Markus
