[GRASS-user] Using Python scripts that call GRASS modules or access GRASS layers from outside the GRASS.app with Mac OS X: a little summary
Tue Jul 10 02:16:47 PDT 2012
gene wrote:
> ok, thanks,  you are right, I wrote too fast...
> So, the correct environment variables for Mac OS X are:
> $ export LD_LIBRARY_PATH="$LD_LIBRARY_PATH:$GISBASE/lib"
I belive that this should be DYLD_LIBRARY_PATH. That's the variable
which is used in grass.py or init.sh.
