[GRASS-user] problem with grass 6.4.0
Alberto Pettazzi
alberto.pettazzi at meteogalicia.es
Wed Jul 11 02:17:52 PDT 2012
Dear all,
I was using GRASS version 6.3.0 and everything worked fine. Now I
installed 6.4.1 on a brand new server and I am experiencing some problems.
I want to run the scripts and the locations I had on the old grass and
when I execute the command on the new version
r.in.xyz i=input_file.txt o=output_file fs=' ' --o
this is what I get
Reading data ...
ERROR: Bad y-coordinate line 1 column 2. <>
the file I am trying to read from has the following structure
-7.830 43.050 0.000
-6.930 42.470 0.000
-8.530 42.280 0.000
-7.640 41.710 0.000
-7.790 43.050 0.000
-6.900 42.470 0.000
and if I run the same r.in.xyz command in the old server I can import
the file correctly.
Why????
Alberto Pettazzi
MeteoGalicia - Departamento de Climatología y Observación
Consellería de Medio Ambiente, Territorio e Infraestruturas
Rúa de Roma, 6
15707 Santiago de Compostela. A Coruña
Teléfono: +34-881-999646
e-mail: alberto.pettazzi at meteogalicia.es
<mailto:alberto.pettazzi at meteogalicia.es>
